Go Back   Home > Forums > Amplifiers > Class D
Old 18th November 2009, 08:50 PM   #11
Hi sexya,
I have output inductors, I just think you are mistaking them as a capacitor, but they are 47uF inductors and they are marked with the letter "L" for inductor.
I haven't quite yet understood why the groundings for the LC filter also must be connected to negative supply. Isn't it supposed to filter both positive and negative signals since audio is AC? or does it still do its job with negative as ground?
Simon H.A.
Old 18th November 2009, 09:03 PM   #12
theAnonymous1's Avatar
On your PCB layout you have the upper right most 470uF cap straddling two grounds that aren't even connected together.
"If you don't like funerals don't kick sand in ninja's face."
Old 18th November 2009, 09:06 PM   #13
Do you mean these two caps?
Old 18th November 2009, 09:11 PM   #14
No. It's the one with the arrow pointing at it in the below pic.
You have it's + side connected to the output ground and its - side connected to the input ground. The input and output grounds are not connected anywhere on the layout.
EDIT: Same goes for the 10uF next to it.
I would get rid of both of those caps and connect the two grounds at that point. Also, as previously stated, you don't have any DC blocking caps in series with the output (unless you plan to add them externally).
Old 18th November 2009, 09:20 PM   #15
lol I was dumb right there.
So actually it is the best not to have any of these on the pcb? So I should just have the speakers connected to the speakerground from my powersupply?
Here is a new layout where the filter is connected to the negative supply, is it correct now?
Edit:
I will also add the DC blocking caps. Does they also improve the performance?
Old 18th November 2009, 09:26 PM   #16
I'm not an expert on grounding (or anything for that matter), but I would put the ground connecters back on the PCB like you had them. You have room to put the two output caps next to the inductors connected in series.
Old 18th November 2009, 09:29 PM   #17
Sorry, I'm getting some of what you say, but could you maybe draw it for me so I'm totally sure of what you mean?
Simon H.A.
Old 18th November 2009, 09:50 PM   #18
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Where is the double sided PCB with a good ground plane and the ceramic SMD decoupling caps? This is class D, no TDA2030 the difference between working or not working may be just some PCB track and capacitor lead parasitic inductance :P
I use to feel like the small child in The Emperor's New Clothes tale
Old 18th November 2009, 09:58 PM   #19
Sorry, I don't have time at the moment. It's all right there in the datasheet though. Take a look at figure 28.
Maybe looking over the evaluation module datasheet will help you out some as well.
http://focus.ti.com/lit/ug/slou214a/slou214a.pdf
Old 18th November 2009, 11:14 PM   #20
I get it all now how it works.
Thanks to you all for using your time to help me.
I have created a new layout and I will try make it and just cross my fingers for that it is stable.
I have made a good ground plane now, and I really like this new layout. I think it will be stable with this board layout.
Thanks a lot for all the help everyone, this forum is very nice.
Simon H.A.
TPA3122 Groundings Cyberzim Class D 6 19th September 2009 12:28 AM
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 04:29 PM
Sub not working with CD (works fine with radio or iPod) puttsthree Car Audio 4 27th December 2007 07:26 AM
Sony STR-DE945 - 'A' speakers suddenly quit, 'B' works fine fridayfriday Solid State 11 8th July 2005 03:13 AM
Page generated in 0.11492 seconds (74.77% PHP - 25.23% MySQL) with 11 queries
