Go Back   Home > Forums > Amplifiers > Class D
Old 17th November 2009, 11:22 AM   #11
sled108 is offline sled108  United States
sled108's Avatar
I'm always Careful with it and keep an Eye on the Red Light, but TriPath states it has a Absolute Max of 16v, and an Operating Max of 14.6v...
Old 23rd November 2009, 07:57 PM   #12
@ Studiostevus: Here are 2 pictures of mine. On the photo the box still contains an original ta2024 board from SI but right now it contains the ta2020 board from Arjen. It was a bit tough to get it all in, since the box is rather small, but it worked out. The box is from Conrad.nl.
For some nice cases you can also check out Electronica Behuizingen
or Class-T special project cabinet - /piece for a (almost)ready made t-amp case.
Arjen's board really rocks btw, you'll love it I'm sure.
Old 24th November 2009, 01:35 AM   #13
vaughn is offline vaughn  United States
Yes it does, I have been using one with my Klipsch Forte's and powering it alternately from a smps or a battery. It sounds terrific with either but there is something special happening with the battery power
Old 24th November 2009, 06:52 AM   #14
Those are the modushop.biz Italian casings... just without the transportation cost from Italy (at least if you're in The Netherlands). Good to know, bookmarked.
I got a hammond Black Eurocard casing eventually. Only problem is that it only opens on both ends of the casing, not on the top. So it will be a bit of a struggle to get it all in. For now I'm playing out of a cardboard box
Display Electronics - Hammond 431621 - Hammond aluminium profielbehuizing zwart, 165 x 105 x 60mm
Old 29th March 2010, 05:45 PM   #15
I'm getting one of Arjen Helder's TA2020 MkIII boards and am wondering whether it's possible to repurpose the 12v power supply from an old yamaha cd-writer (CRW2100). Can I just connect the output from the psu to the TA2020 board? I'm a newbie so would like some advice before I do something foolish (I don't know what the current output of the psu is and i'm not clear whether it will overload the board and fry it!)
Thanks (first post so be gentle),
Dan
Old 29th March 2010, 08:49 PM   #16
mfong is offline mfong  United States
ticklerton,
it'll likely work, though the specs for the power supply should be printed on the unit. Just be careful to connect the wires correctly (some cd rom power supplies are 12 volt and 5 volt). I use discarded laptop power supplies and a printer supply for my tripath amps and I've tried a supply for an external IDE hard drive and that worked fine.
Overvoltage might fry the board (I did it a couple times). Overamperage usually isn't an issue
Old 29th March 2010, 10:59 PM   #17
mfong,
Thanks for quick response and advice. Yes, power supply is 12 volt and 5 volt. As both 12 and 5 volt wire sets are enclosed in a run of cable I can't tell which red and black wires at the pcb end are for which rail. (There's also a fan which I'd like to disable.) Can I just leave that end alone, cut the connector that previously went into the CDRW drive and use the wires I need (ignoring all the ones I don't) or will I need to chase back the cable and establish which pins are 12V and G?
TIA, Dan
Old 29th March 2010, 11:38 PM   #18
the ground is probably black. Easiest way to tell which is 5 and which is 12 would be to use a volt meter.
Lepai T-Amp with TA2020 Fin Class D 1166 Yesterday 04:38 PM
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 97 8th February 2011 11:22 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Page generated in 0.08884 seconds (83.96% PHP - 16.04% MySQL) with 11 queries
