Go Back   Home > Forums > Amplifiers > Class D
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 7th November 2009, 05:06 PM   #1
Default Checking for PCB errors
Hi there,
I have made a pcb layout for a tpa3122 amplifier.
My problem is, that the last board I made costed me 4 of these amps since I had some errors and so on, but now I think I have fixed all the errors, but I would really appreciate if you could just use a bit of your time to look on my pcb and see if you can find any errors.
Here is link for datsheet, and you will find the schematic under "Application Information" http://focus.ti.com/lit/ds/symlink/tpa3122d2.pdf
Here is the pcb: Imageshack.dk
The yellow lines are jumpers.
I can't afford any more mistakes
Thank you,
Simon H.A.
Old 7th November 2009, 08:09 PM   #2
m-tech is offline m-tech
Analog and power ground should be connected at single point on pcb. You didn't connect them ( "-" and "GND" on your pcb ).
Old 8th November 2009, 10:37 AM   #3
So what you mean is, that analog ground and power ground is the same?
Old 8th November 2009, 10:54 AM   #4
FAA is online now FAA
yes, you can also try to rotate 90deg counterclockwise the two inductors
Old 8th November 2009, 03:55 PM   #5
I fixed the "gnd" and "-" together to one point so there should not be anymore errors.
Here is the new layout.
Is it correct now? If it is then I will etch a new board and test it for results.
Thank you,
Simon H.A.
http://imageshack.dk//viewimage.php?...e/TDA99277.png
Old 11th November 2009, 11:08 PM   #6
I've burned my last chip, so I will order new chips and go back to breadboard again.
I found a picture of my breadboard setup, and the Analog Ground was separated, so that power ground was the negative supply and analog ground was ground as you know with analogs.
When I get the same performance again as I did with my breadboard I will make a new pcb and try again
This is getting expensive
Simon H.A.
Old 12th November 2009, 09:28 AM   #7
This is my version www.sendspace.com/file/5g8sab
Old 12th November 2009, 09:53 AM   #8
Thanks for the post !
I have one question about the schematic. I'm often confused by the ground.
Is the ground in this schematic the negative supply? you know if we say we use +/- supply
Thank you,
Simon H.A.
Thread Tools
15W kit schematic errors! N9VOC Chip Amps 3 30th March 2008 09:47 PM
First PCB Design. Any Errors? BubbaGump Chip Amps 5 13th August 2007 07:12 PM
Errors with DIY JLTi schematic DragonMaster Chip Amps 0 6th May 2006 01:54 PM
need help in correcting errors urgently weifeng Parts 5 13th February 2006 12:54 AM
denon dcd-485 cd errors hlp req plz fender62 Digital Source 1 15th August 2005 01:48 AM
Page generated in 0.07505202 seconds (78.89% PHP - 21.11% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
