6000W By IRS2092 - Page 38 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 19th November 2012, 05:55 PM   #371
what about exit core ?
T106-2 ?
how much powere can handel T106-2 ?
Old 20th December 2012, 06:49 AM   #372
The mosfet driver totem pole BJTs are rated 80V so the
supply must be below +/- 80V.
Old 31st December 2012, 04:08 PM   #373
aman khalsa's Avatar
happy new year to all diyers.....
Old 31st December 2012, 07:00 PM   #374
stewin is offline stewin  Kenya
happy new year diy audio world
and a happy and a prosperous new year
Old 3rd March 2013, 05:20 AM   #375
Default this is pcb layout
Originally Posted by DJ_DUMY View Post
hi
I designed a PCB for this amplifier but I replace transistors with two driver circuits if you have something better please send to me at gabriel_seku@yahoo.com
Old 28th March 2013, 05:20 PM   #376
vdij is offline vdij  Moldova
IRS2092+UCC37322+IRFP4227, U+-65V, R-4 Om.
File Type: png Snap 2013-03-27 at 23.10.26 - копия.png (56.4 KB, 244 views)
Old 29th March 2013, 04:26 AM   #377
student_sound's Avatar
Default Hi vdij !
Hi friend !
can i ask you some things ?
i m new in class d, i built irs2092 amps 7d, with no input signal , but the output have some hi frequency noise like post #7
Sure IRS2092 Amp Issue, Please Help
Can i ask you what's wrong with it ?
Regards !
Old 29th March 2013, 05:46 AM   #378
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Looks good
Any information on your SMPS?
Baldin
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 29th March 2013, 06:04 AM   #379
Baldin's Avatar
Originally Posted by student_sound View Post
Hi friend !
Regards !
What you are probably experiencing is interfeerence from one chenel to the other (called beating), either EMI or through supply. If only on e chenel is connected, do you then hear whistling? If you use a SMPS the problem can also araise between amp and SMPS.
Problem araises from the switching noise generated by the switching components, and especially if you have say two chenels where the main switching freq in two chenels are different by less than 20 kHz.
Proper layout, shielding etc. helps a lot. but try lowering the switch freq of one chanel, or try insert some chokes on the different wires (keep these short ... they are like antennas).
Baldin
Old 29th March 2013, 08:52 AM   #380
Default hi Baldin !
hi Baldin !
Thanks for your replay ! i use classic xfmr power supply, and if i test channel one and channel two shutdown, the result is the same, i dont know why ?
please help me !
Regard !
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright 1999-2017 diyAudio
