6000W By IRS2092
6000W By IRS2092
Old 11th March 2012, 11:29 PM   #341
don2007ksa is offline don2007ksa  Philippines
YES,Nguyen i mean linear power supply
Old 11th March 2012, 11:30 PM   #342
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
How about a irs2092 based system with tc4420 buffers driving two pairs of IRFB4227 ?
This is what I use and it is very loud.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/sch/i.html?_f...nload&_sacat=0
Old 11th March 2012, 11:38 PM   #343
Hi,Nigelwright7557 good day can you post your d design with buffer TC4420 just to compare with nguyen design,thank's
Old 11th March 2012, 11:45 PM   #344
hien.t.nguyen is offline hien.t.nguyen
hien.t.nguyen's Avatar
Send a message via Yahoo to hien.t.nguyen 6000W By IRS2092
I have one design use IRS2092S+IRFI4020H-117P at here:
http://www.diyaudio.com/forums/class...-full-pwm.html
If you use parallel two chanel and connect with 4 ohm load is it is 500W/4ohm
Or you replace one IRFI4020H become two IRFB4227,it maybe up to 1000W/4ohm.
Ultraline1@gmail.com
Old 11th March 2012, 11:51 PM   #345
It is basically the irs2092 datasheet circuit with two tc4420 buffers added.
Old 12th March 2012, 12:25 AM   #346
Yes,at high frequency input impedance of mosfet is low,need use buffer stage to up current driver for mosfets output.
Buffer can use TC4420/4029 or two bjt/mosfet
-TC4429 have input impedance very large,it need current provide (current static) from power supply
-Two BJT/mosfet have input impedance smaller but it is classB => not need current provide from power supply (current startic very small)
Old 12th March 2012, 01:12 AM   #347
The 2092 can drive 1amp5, the 4420 can drive 6 amps.
Old 12th March 2012, 07:01 AM   #348
Thank's to both of you guy's.cheer's....
Old 12th March 2012, 08:05 AM   #349
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by hien.t.nguyen View Post
Sorry,i mistyped ....
If I use 4 ohm load(full bridge),+/-100V,Pmax < 200x200/4 = 10KW(peak) = 7.07kW(rms)
Again mistype
200V (peak )~ 140V rms ,so 140x140/4 =5kW rms
Old 2nd May 2012, 09:04 PM   #350
slshellas is offline slshellas  Greece
Hi Ngthyen,
I'm interested in your bigam design, is there any news on the pcbs. If so, you will be able to upload them to the forum, you plan to sell them, or you be able to upload on my enail : aerasepolia2@gmail.com
Regrads,
6000W By IRS2092Hide this!Advertise here!
Irs2092 luka Class D 50 15th July 2012 02:48 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 01:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 08:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 03:29 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 04:30 AM
