6000W By IRS2092 - Page 26 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd May 2010, 05:42 PM   #251
Account Disabled
Wink Hello
Originally Posted by 81bas View Post
only if it will help you to finish your super-duper professional 4kw SMPS...
You still have to answer my previous question friend.
Old 4th May 2010, 03:53 AM   #252
Originally Posted by ionutgaga View Post
Not quite 6000w, but interesting simple classD topology: IRFB4227, Ir2110, LM319, deadtime with 74HC14, bridge +/-75v, 8 ohm in powered speaker with RCF MB15H401 and Precision Devices PDC2.
It works very well in full range, it is selfoscillating , 400khz at idle, but in this powered speaker i have an active processing, with class AB for highs.
LE. I know that inductors not have optimum position, but it works well, no parasitics.
the eschematic? for pless
Old 4th May 2010, 04:09 AM   #253
Workhorse's Avatar
Old 4th May 2010, 09:30 AM   #254
81bas is offline 81bas  Germany
I do not have to, but you can find the answer in schematics in posts #1 or #2 in this thread
Old 25th July 2010, 03:34 PM   #255
if is possible i want pcb desin this amp irs2092_6kw my mail is malbasicradan@gmail.com
Old 11th August 2010, 10:39 AM   #256
opor is offline opor  Thailand
I have finish this amp with some modifiaction . But I have the problem when start it up. DC offset is about 500mV .There should be something wrong. But I could not find.So I need help.
This is my schematic.
Old 11th August 2010, 10:46 AM   #257
Hi Sorry,
This is lastest shematic. My supply is +-70V.
Old 11th August 2010, 03:50 PM   #258
I gave you wrong informations. DC offset is 26.7V!!! at start up not 500mV. So I have put 1Kohm resistor between output and GND ,DC offset is down to 500mV but just a second it goes to 70V. Why?
Old 11th August 2010, 03:51 PM   #259
And this resistor is getting warm.
Old 11th August 2010, 07:16 PM   #260
I have found the mistake. It is my soldering fualt. Now I was fix. But there is still 500mV DC offset.
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright 1999-2017 diyAudio
