| Class D Switching Power Amplifiers and Power D/A conversion |
#131 |
All.
Can I have PCB and top view componemt for 6KW class"D" please Thanks for your help |
#132 | |
Concerning the diodes, HO should be clamped to VB and VS with schottkys, LO should be similarly clamped to COM and Vcc, and finally VS should be clamped to COM. For HO and LO clamping 1A 20V schottkys are ok, I use low inductance SOD-323 packages. For the later purpose I use a bigger 3A 200V schottky in SMB package (consider figuring out the part numbers as some homweork These diodes may not be always required, it depends on di/dt and layout parasitics. My layout is good, but I also use insane turn-off di/dt close to 4KA/us resulting in negative Vs spikes of more than 5V at high output currents and also negative spikes on HO and LO, so the diodes are almost required for reliability. At some point in the development I added buffer transistors to the outputs of the IR2110, which greatly reduces the need for diodes on HO and LO because the chances for negative or positive spikes are reduced, but I dediced to keep the diodes. On your schematic the value of C2 is way too high and the connection seems quite strange, I have not tried to simulate it in detail but I think it's calling for trouble. Concerning XOR gates, you may find 74AHC1G86 (74LVC1G86) single ones in SOT23-6 (and smaller ones too) to be quite useful. 74LVC1G57 and 74LVC1G58 are also quite versatile. LVC seems to have higher output current than AHC.
I use to feel like the small child in The Emperor's New Clothes tale Last edited by Eva; 21st January 2010 at 01:46 PM. |
#133 |
Hi Eva
Hmmm, had not seen this reply before now? .... Thanks for the tips. Well it's an awful lot of diodes to find room for, but I think I might be experiensing the lack of these at the moment. Funny things are happening when either I remove the load or I try to start up without (shoot through instability). Have tried to mount a 10k resistor from com to Vs as suggesed in IR DT 99-7, which at least prevent shoot through when starting up with no load ... but it the IF2110 dosen't start switching either ..... I'm scratching my head, and it must be something with the working of the IR2110 in the un loaded state .... Home work: 1A/20V could be On's NSR1020MW2T1G and the 3A/200V could be MBRS3201T3G ![]() Haven't any schottkys at the moment, but will try with some ES1D As to the size of C2. Yes it's too big, but was only for the first trials to make sure there was enough dead time. Now running with 100pF, on FETs without heat sink. With a little alu on the FETs I could probably go down to 10-33pF. The connection is right I belive, and it's running without any problem. You culd use two caps going to GND, but this connection saves one and works as well.
#134 | |
![]() http://www.irf.com/technical-info/appnotes/an-1100.pdf
#135 |
dear sir
greetings which city in india do you live in thanking you andrew lebon |
#136 | |
.... makes sense ![]() But thanks for the heads up ... will bye the IRS version next time
#137 |
I just tried to clamp the output (just after the filter) with 2 diodes (ES1D).
I will still try all the other clamps, but I was actually wondering what would happen to the stored energy in the filter, when the load is just removed. It might not be much in idel mode or just playing softly, but otherwise a large current would give rise to a very high voltage on the output .... It did help; removing the load, it still keep oscillating, but nor stable, and there are still some shoot through .... Eva and Workhorse, do you also use clamping dirodes on the output?? |
#138 |
Clamping diodes at output in class-d after the filter helps when amps are working in bridge mode especially when the speaker load is highly reactive.
#139 | |
#140 |
Ok, did the clamping:
COM to LO to VCC, and VS to HO to VB. Did it with 4 x 1N4148 as this was what I had. No improvement what so ever ![]() VS is already clamped to COM through lower bodydiode and external ES1D in parallel. Don't know what is wrong
| Irs2092 | luka | Class D | 37 | 31st January 2012 05:45 PM |
| IRS2092 on breadboard | rob mullen | Class D | 31 | 27th November 2010 01:24 AM |
| Another amp with IRS2092 | mag | Class D | 23 | 18th June 2010 08:25 PM |
| IRS2092 AMP help | yaronshani | Class D | 3 | 29th January 2010 03:29 PM |
| IRS2092 help! | yudi02 | Class D | 2 | 11th October 2009 04:30 AM |
| Page generated in 0.13133 seconds (80.95% PHP - 19.05% MySQL) with 11 queries |
