Go Back   Home > Forums > Amplifiers > Class D
Old 19th December 2009, 10:15 AM   #111
darkfenriz's Avatar
I am a bit suspicious about mosfets rated 200V and more. For a given technology level and current rating, the capacitances and miller charge seem to go propotionally to VDS rating, while body diode charge seems to rise more or less proportionally to third power of VDS.
You may be much more "headache free" when switching at 60-100V VDS and bridging.
For my next project I plan to use a "bridgeable bridge" topology with four floating half-bridges to get +-100V output swing with 60V devices (Qgd=6.3nC, Qrr=17nC)
Old 19th December 2009, 11:58 AM   #112
No doubt, MosFets and especially their body diodes are quite 'ugh' above 100V.
It would be nice, if you could post a simplified principle of what you call a bridged bridge. My brain does not deliver a prompt translation from 'bridgeable bridge' into a schematic.
I am aware of staggering the power stages by using multiple floating power supplies. And such concept would again allow to be bridged (ref. attachement). Theoretically this concept would even allow multi staggering, not only 2 times, but 3..4..5...
But also there - probably the lunch is not for free.
If you skip the filter inbetween, you will get large circuit areas with giant dv/dt versus earth... generating an EMI hell. If you put the filter inbetween - you get more phase shifts and delays, resulting in less freedom for feedback and stability. Of course a trade off with a fast filter might be an option.
Curious about you conceptual schematic...
Old 19th December 2009, 02:22 PM   #113
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Is it something like patent#6097249, where the supply can be switched to ground?
Old 19th December 2009, 02:27 PM   #114
81bas is offline 81bas  Germany
What you will do against the bus pumping effect in floating PSUs?
Old 6th January 2010, 01:23 PM   #115
cccv is offline cccv  Latvia
What do you think about this mosfet STW13NK100Z
Old 6th January 2010, 02:02 PM   #116
Rds-on is too high (0.56 Ohm)... Current capability is too low (13A)...
Old 7th January 2010, 04:32 PM   #117
fredos is offline fredos  Canada
body diode way too slow...
Old 7th January 2010, 05:45 PM   #118
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
For ~1000V class D?
I use to feel like the small child in The Emperor's New Clothes tale
Old 7th January 2010, 08:30 PM   #119
just for safety. but why not?.. if I take this parallel?
Old 8th January 2010, 06:20 AM   #120
Eva's Avatar
With good PCB layout and gate drive, MOSFET can be used at nearly it's rated Vds, and on the other hand, higher voltage devices have higher capacitances and impose a lot of restrictions on how their body diode can be used. So using parts with higher Vds than required is not a good idea.
Most MOSFET rated at 100V and less will handle body diode hard switching without problem. Some 150V parts are suitable too. With well controlled di/dt, a few 200V/250V ones, and very few 500V/600V ones will handle it too, but charge storage results in high losses on the latter. All higher voltage parts would need external diodes.
IRFB4227 and IRFB4127 are rated at 200V and still can handle hard switching with reasonably low losses. Also, low Rds-on allows to bypass the body diode up to a certain current level (depends on temperature). In my current project, body diodes are only used with 2 ohm load.
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright ©1999-2013 diyAudio
