| Class D Switching Power Amplifiers and Power D/A conversion |
Anyone tried a hypex UCD400 amp with a hypex SMPS400 power supply? The supplty alone outputs the right voltage but when I hook up the UCD400, the supply jumps to only 12V, then resets back to zero after 75ms. This cycles every 1.75 seconds.
I've only hooked up the +70V, GND, and -70V. I've emailed customer service there but thoght if it's something simple I've done, I could get a quicker answer here. What am I missing? Thanks, Phil |
#2 |
Never mind! I found my problem and am way to embarrassed to admit what I did!
#3 |
Well, that is not very educational. Could you please explain were you went wrong? I am waiting on one of there puppies myself.
#4 |
I'm embarrassed damn it!
OK, I'll fess up and blame it on old age. ![]() I hooked up the power to LS+ and LS- and hooked up the speaker to + and -. The really embarrasing part is I am a retired electrical engineer with half a dozen patents! Just to be perfectly clear LS stands for Loud Speaker, not power! There, happy? P.S. After I corrected the wiring, it all worked fine with no apparent harm to either the speaker or the amp or the power supply. Last edited by Phil Olson; 11th January 2010 at 05:16 PM. Reason: Additional info. |
#5 |
Everyone can have a bad day right?
Anyways, glad it worked out allright for you. |
#6 |
Hey Phil,
It can happen but now we are sure of the rugidness of the Hypex modules. Cheers, Tarzan |
#7 |
We knew that already. What was tested here I think was the SMPS's overcurrent protection, looks like it worked. The module would have completely fried without it, or blown the rail fuses that probably wouldn't have been installed, or likely fried them both along with the module had they been.
James J. |
| problem with ucd400 | slr 5000 | Class D | 9 | 31st January 2009 03:27 PM |
| UCD400 problem | lucpes | Class D | 0 | 18th May 2008 07:11 PM |
| UCD400 Amp | john65b | Swap Meet | 4 | 13th November 2007 12:08 AM |
| UcD400 Problem | tomahack | Class D | 31 | 29th September 2005 10:13 PM |
| Page generated in 0.08896 seconds (72.03% PHP - 27.97% MySQL) with 10 queries |
