Ever tried the type 0 toroids?
Old 12th October 2009, 05:19 PM   #1
sendler is offline sendler  United States
Default Ever tried the type 0 toroids?
Anyone ever tried the type 0 toroid cores to see if they sound more like an air core than the type 2 that is most often recommended?
T130-0
Scott
Old 12th October 2009, 06:19 PM   #2
Pafi is offline Pafi  Hungary
Why would anybody try a practically non-magnetic core?
Old 12th October 2009, 07:21 PM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
A toroid will have much less radiation/crosstalk
I suppose its an iron powder core for the small output inductor, and very few windings are needed
Pure iron core I would avoid, if possible
But I dont understand whats new about it
Old 12th October 2009, 08:57 PM   #4
Default Practically non-magnetic core
I would audition the type 0 To try to get closer to the sonics of an air core while still containing EMI enough.
The sonics of the type 2 core are no where near as good as an air core and if I can't find an inductor that will shield AND sound good, I will have to abandon class D and go back to class AB.
Scott
Old 12th October 2009, 09:20 PM   #5
Maybe it's iron powder, but it has only 50 % bigger permeability then air, so I would say its almost nothing. Al=1.5 nH/turns^2 --> 20 uH needs 115 turns. I wouldn't say it's very few. A little bigger plastic or wooden ring will do it as well as this expensive ****.
sendler! If you want something like air-core, then use air-core! If the choke forms a toroid, then the radiation will be low. But it needs much more wire then a usual air-core coil!
Old 12th October 2009, 09:21 PM   #6
wrenchone is offline wrenchone  United States
wrenchone's Avatar
The type 0 core is simply phenolic plastic, so it is equivalent to having an air core, except that you have something on which to wind the wire.
Old 12th October 2009, 09:42 PM   #7
Default Air cores do pollute
I have some single layer cylindrical air core filters built but they do pollute an AM radio up to 20 feet away so I only run them for brief comparisons. I have adequate filter response with the inductors down to 6uH so I am looking at 30 inches of wire with the type 2 core versus 90 inches. It's worth a try if no one else has already done it.
Scott
Old 12th October 2009, 09:47 PM   #8
Ahh, ofcourse
THEN a hardwood toroid core with rounded edges would be nice
Make it yourself, thats not difficult
The best for free
Old 12th October 2009, 10:07 PM   #9
No, the core doesn't pollute. The wire does, if it's not compensated by other wire (like at a usual toroid). The toroid core does not shield!
Old 13th October 2009, 02:23 AM   #10
Default Multiple layers?
What are the draw backs to multiple layers of windings on a toroid if you commit to two full layers? They are used in transformers but rarely seen for inductors.
Scott
Ever tried the type 0 toroids?Hide this!Advertise here!
Re : BL type & GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 06:15 PM
WTB: 43-0-43 or 46-0-46 Toroids K-amps Swap Meet 3 17th November 2006 08:03 PM
which are the BEST toroids? Mecanp Solid State 21 10th February 2003 03:20 PM
Toroids (four) JohnR Swap Meet 1 1st February 2003 02:39 AM
