Ever tried the type 0 toroids?
Old 14th October 2009, 12:35 AM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
What I dont understand, why is such a thing placed on the board in the middle of sensible curcuits
Wouldnt it be better placed between board and output terminals
Well, maybe its obvious I have no idea what its about
But I am interested because my next woofer amps might be classD
And I have always thought the used output inductors looked pretty awful
Old 14th October 2009, 07:56 AM   #22
phase_accurate is offline phase_accurate
The leakage comes from imperfections, for example when you wind the turns in a way that it goes around along the core, then you make a single turn choke in excess the toroid. Not equal distances are the other source of leakage.
Even if a toroidal coil is wound perfectly it still has one single loop that is causing a stray field. And this is unavidable. Don't forget about that !
Charles
Old 14th October 2009, 08:07 AM   #23
Pafi is offline Pafi  Hungary
I didn't forget, I wrote about it! (Maybe I wasn't totally clear.) But actually it is avoidable! With two layers. Or it can be minimized with only one layer, if you split the coil into two symmetric halves, then connect them paralell (very small values) or series (higher values). You can decrease it further, use your imagination!
Old 14th October 2009, 10:23 AM   #24
Lostcause is offline Lostcause  United Kingdom
Lostcause's Avatar
Default if you can't contain it shield it?
I thought the same thing and started placing them under the PCB into one of those small shielded boxes you can get and earthing it to the case... which is in turn earthed to the UK third pin.... no idea if it makes any difference but I feel better for doing it
Damn... why didn't I think of that!
Old 14th October 2009, 11:01 AM   #25
Charles!
Another simple way to eliminate the flux leakage caused by the loop: before winding the coil make a loop in the other direction!
Old 14th October 2009, 11:11 AM   #26
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
You're still under the misconception that you can eliminate the flux leakage entirely. Let me assure you cannot. And while that may not make a difference in low frequency applications, it certainly does in high frequency ones like this.
The traditional advice for output trafos in class-D is to use heavily cored and heavily shielded trafos. Stick to it.
Old 14th October 2009, 11:43 AM   #27
No, obviously I haven't said (or thought) this. Please try to understand what I wrote! Simply denying is pointless.
What is your problem exactly? Does the knowledge about leakage mechanism hurt you? Do you sell magnetic shields? Or what?
I don't know why have you told this, and what does it mean.
Old 14th October 2009, 11:51 AM   #28
Saturnus's Avatar
It means that high frequency operating cores like in the output of a class-D will always function best the less parasitic resistance and capacitance it has, both are ensured by correctly coring the trafo. Air cores of any type should be avoided at all cost to achieve the best sound.
Old 14th October 2009, 12:14 PM   #29
ClassD what? ClassD amplifier? Then why did you write trafo? ClassD power supply (it contains trafo indeed)? How does it come here?
Parasitic resistance and capacitance of a core? I think you are lost somewhere!
Doubtfully. You forgot about many important things.
And by correctly wind it, with the correct wire, with the correct insulation.
Tell this to Sendler, I'd ended up the idea of using air core many years ago! (Unless it's for an induction heater.)
Old 14th October 2009, 02:15 PM   #30
Saturnus's Avatar
ClassD what?
Output coil! If you don't understand that this is the class-D forum, and as such any discussion about cores and coils herein would be relevant only to the output filter coil(s), then I can't help you further.
Ever tried the type 0 toroids?Hide this!Advertise here!
Re : BL type & GR type of transistor for Aleph-Ono Arion Pass Labs 4 29th January 2007 07:15 PM
WTB: 43-0-43 or 46-0-46 Toroids K-amps Swap Meet 3 17th November 2006 09:03 PM
which are the BEST toroids? Mecanp Solid State 21 10th February 2003 04:20 PM
Toroids (four) JohnR Swap Meet 1 1st February 2003 03:39 AM
Copyright ©1999-2017 diyAudio
