speakon in DIY amp?
speakon in DIY amp?
Old 26th October 2009, 12:49 AM   #21
Huberto75 is offline Huberto75  Ireland
Hi. new here so please have mercy
I'm working with pa stuff an speakons all the time and that would be the last thing I would use for my hifi . Great for PA and only PA !
regards
Old 26th October 2009, 04:28 AM   #22
pheonix358 is offline pheonix358  Australia
pheonix358's Avatar
Originally Posted by d to the g View Post
Done. No difference whatsoever. None.
I agree after extensive testing, they are that good.
Terry
What we don't understand is called magic.
Old 26th October 2009, 06:47 AM   #23
Brett is offline Brett
Brett's Avatar
regards
Why?
Old 28th October 2009, 03:30 PM   #24
Hi Brett.
Main reason is that I had to replace few of them that went faulty.
As it is spring loaded contact with small area ,I more like the binding post with greater area and force.
But that's just my opinion .
regards
Old 1st November 2009, 04:54 PM   #25
Duffy Moon is offline Duffy Moon  United Kingdom
Duffy Moon's Avatar
Hi Brett.
regards
Were they Neutrik? I can't imagine how they could break - they are very robust.
I like to use Neutrik connectors for everything. They are widely available, look great, are robust, well-made and all fit the same hole. They also sell for sensible prices. I think someone would have to provide pretty substantial evidence to make me want to change.
Since they are used commercially, surely the equipment used to record the music you listen to will have Neutrik connectors? Nuff said.
Old 1st November 2009, 05:04 PM   #26
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
I bought some non-Neutrik femail Speakon connectors for cable (as Neutrik does not make this) ... and these where of a totally different build quality ... looks good, but I'm sure will not last half the time of the real stuff from Neutrik ....
But it would be very interesting to get some feedback on this from people like huberto75 who are using these connectors in PA equipment and sees the equipment for service...
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 1st November 2009, 05:25 PM   #27
Duffy Moon's Avatar
Actually...
NEUTRIK SPEAKON NLT4FX Female cable
They also make in-line couplers:
NEUTRIK SPEAKON NL4MMX In-line coupler
I don't work for Neutrik BTW
Old 1st November 2009, 09:18 PM   #28
Hi
they were neutrik , but those were amps used for gigs , so wery bad and often usage (abuse probably).
I also don't like banana plugs
Old 1st November 2009, 09:37 PM   #29
Brett's Avatar
Agreed. I dunno how any reasonably sensible person could damage them, especially domestically. When I had for hire PA systems they used Speakons and the klutzes that hired the systems never managed to break one.
Old 1st November 2009, 09:52 PM   #30
col is offline col  Australia
col's Avatar
I have had the binding pins inside the male connector roll out of the plastic casing instead of locking in the early versions of the cheap copies. I posted this photo earlier, the ones with the cross should be avoided if possible.
16102009244
the later version cheap copies that are tapered seem fine.
col.
http://www.minirig.org.au
speakon in DIY amp?Hide this!Advertise here!
Speakon sockets - how to fit? aquapiranha Construction Tips 7 25th September 2009 04:26 PM
Speakon screws? MikeHunt79 Parts 12 7th May 2008 09:21 PM
speakon to RCA help joka22 Solid State 11 15th July 2007 04:08 AM
Speakon Na4lj wotsascott Parts 3 7th July 2006 04:42 AM
