Go Back   Home > Forums > Amplifiers > Class D
Old 5th October 2009, 10:20 PM   #1
Default Audiom | 100-W audio amp is 20 times more efficient than Class D chips
Thought somebody may be interested in this:
http://www2.electronicproducts.com/1...009.html.aspx#
Old 5th October 2009, 10:36 PM   #2
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
100w peak from 1.5v supply?
i thought this was october ...
(vs. april)
mlloyd1
Old 6th October 2009, 12:28 AM   #3
20 times more efficient? Gee, worst-case class-D is 70% efficient, so this thing must be 1400% efficient! Call the Nobel Prize committee, we've discovered the secret of endless power!
That's what happens when you let the marketing pukes put out a press release before the engineers fact-check it.
Old 6th October 2009, 12:32 AM   #4
Iain McNeill's Avatar
http://www.audiumsemi.com/technology.php
someone should tell them that they haven't released a title with high peak-to-average-power ratio in almost 30years.
Old 6th October 2009, 01:14 AM   #5
stoc005 is offline stoc005  United States
stoc005's Avatar
Default I'll wait for the one powered by interstellar ether.
Old 6th October 2009, 01:31 AM   #6
star882 is offline star882  United States
star882's Avatar
Is it hybrid or pure digital? Not that it matters as it appears to be vaporware and not smugware...
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 6th October 2009, 01:38 AM   #7
No, I think it's a real chip. From what I can gather it's a class D driver chip with an on-board look-ahead SMPS. The SMPS steps up the 1.5V to whatever rails are needed by the class D amp to output the signal and then the class D drivers have their losses minimized by only switching the voltage needed (rather than required full power rails) and also due to longer on-times. All the power devices are off chip. This is just a controller.
I'm sure it's really good for a wristwatch boom box but that 100W spec has some very specific conditions on it. It sure as hell ain't gonna run no 15" subwoofer off a AA battery.
Old 6th October 2009, 01:44 AM   #8
cbdb is offline cbdb  Canada
They could increase the voltage out with a switching reg type cct (isnt this what class D is) (12v car amps can put out 1000w) but which pin is the 100amps going thru?
Old 6th October 2009, 03:18 AM   #9
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
They talk about "small batteries", wich cannot offer 100 watts, not even in 20msec burst,and that's for an 100% randament!
That's a LIE, or, maybe they have discovered, new phisic laws...
Old 6th October 2009, 04:37 AM   #10
Electrons are yellow and more is better!
peranders's Avatar
You must read more carefully. The chip goes on 1.5 volts but the power transistors will have more.
/Per-Anders (my first name) or P-A as my friends call me
12VDC Class-D Chips speaker Class D 3 9th February 2008 12:42 PM
Class D PWM chips wassyq Class D 1 3rd October 2007 09:59 PM
Efficient sub for Omnes Audio L8's inrank Subwoofers 15 19th October 2006 12:05 PM
Need help getting info on Class H+ chips DonoMan Chip Amps 4 20th October 2005 08:11 PM
good class d chips sagarverma Class D 0 8th October 2005 07:46 AM
Page generated in 0.09819 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
