Go Back   Home > Forums > Amplifiers > Class D
Old 29th September 2009, 09:21 AM   #1
Default Amps for a 12v battery based sound system
Hi Folks,
I'm working on a 12v deep cycle battery based sound system for a friend. Obviously the efficiency of class D amps could be quite useful. What I'd like to know is:
- what class d modules are particularly suited to 12v rails
- if any of the above are stable into a 2ohm load
The lazy solution would be a couple of the dayton tripath amps, but I imagine there's probably better options out there.
Old 29th September 2009, 10:03 AM   #2
Saturnus's Avatar
Any Tripath 2020 based amp is optimal as they are 2 Ohms stable with sufficient cooling. The Dayton is not suitable for your use as it's not 2 Ohms stable, and it's also too expensive in my mind compared to paying a little extra for one of the much better Tripath 2020 based amps out there (41Hz, Topping, Hlly and so on).
See link in sig for ideas/solutions.
Old 29th September 2009, 01:34 PM   #3
I'll second Saturnus' suggestion and toss in the 2021b, which is pretty much the same thing in a smaller package, if space is a concern. It may be found in various 41hz kits like the Amp32. Be advised, it's all surface-mount, and a pretty challenging build. But, it has the footprint the size of a large postage stamp.
--Buckapound
Sound Card Based Audio Test & Measurement System, 21-day fully functional Free Trial! VIRTINS Vendor's Bazaar 43 29th July 2011 04:10 PM
High Sensitivity Subwoofer for 12v battery based system jason_watkins Subwoofers 13 31st October 2009 08:04 PM
Battery Based High-End DA Converter. yangsmm Vendor's Bazaar 14 21st August 2008 01:24 PM
Running a US based sound system in Japan. imix500 Everything Else 0 24th May 2006 04:14 AM
Efficient spkr req' for battery system. Mark25 Multi-Way 9 3rd December 2003 09:52 AM
Page generated in 0.07135 seconds (71.74% PHP - 28.26% MySQL) with 10 queries
