diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   look at low power amp for 4x SqueezeBox Duet (http://www.diyaudio.com/forums/class-d/152392-look-low-power-amp-4x-squeezebox-duet.html)
psykosonik 24th September 2009 03:41 AM
Hello,
Looking for a suitable amp to power 4 Squeezebox units. I am hoping to store everything in the cupboard along with the amps.
The amps will be always on unless there is a audio signal to turn them on, I'll be controlling the volume via the remote on the squeezebox so the amps will have the master volume adjusted.
Apparently there is a descent DAC on the Sqeezebox's and would like to utilise this.
Will be buying some speakers after I choose the amp.
Does anyone have a solution?
psykosonik 24th September 2009 11:33 PM
Signal Detecting Auto Power-On Unit
Found a circut that will dectect a singnal and turn power the amp http://sound.westhost.com/project38.htm
Will this work with the Topping TP10 Mk3 or TP20 amps to power some in wall or ceiling speakers?
I want low power consumption and dont think it would be wise to keep these little amps on 24/7 365 days.
Sedweck 2nd October 2009 05:42 PM
Hi - check out www.sumoh.com
Cheer
Copyright 1999-2017 diyAudio
