Go Back   Home > Forums > Amplifiers > Class D
Old 31st January 2012, 12:11 AM   #31
nigelwright7557's Avatar
Are you not using a heatsink ?
Are the inductor wire holes big enough ?
The layout looks about as tight as you can get it.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 31st January 2012, 12:19 AM   #32
-The heatsink will be under the pcb.
-The inductor wire hole match correctly.
-I want to get a small pcb
But what do you think about layout?? I have no experience wiring Class D amps
regards!
Old 31st January 2012, 07:11 AM   #33
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
This looks good, I don't think you need those diodes, above inductor... you do have them in fets if they would be needed: In fact only diodes in some app are somewhere around IRS, those you might want to add
I think you are ready to build it
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 31st January 2012, 08:07 AM   #34
Ty luka!!
I'm working on it
where can I see your irs2092 pcb assembled??
regards!
Old 31st January 2012, 08:57 AM   #35
luka's Avatar
Originally Posted by electroconico View Post
Ty luka!!
I'm working on it
regards!
I don't think I posted it yet, not that I would remember.
Status is, both channels are working, you could say I am testing it from time to time. One still need to be updated (1st one) to be able to get higher sw. freq. and I think I will add filter from one of the IR app notes, to lower some noise. And still unsure, if I would stay on current inductors or not, they are t106-2
I FEEL SLOVENIA
Old 31st January 2012, 03:15 PM   #36
Ohh That's why i couldn't find it xD.
Thanks again!
regards!
Old 31st January 2012, 03:24 PM   #37
andrewlebon's Avatar
Default CLASS D high power
Hi Luka
greetings the amp you have made with IRF4227 what will be power in 4 ohms
supply 90 volts dc positive negative and from where you buy tl106-2 core
warm regards
andrew lebon
Old 31st January 2012, 04:45 PM   #38
luka's Avatar
I don't know what would be the highest voltage I would go for, +/-70 to 75v is what I have, I guess around here, this should give well over 400w into 4R, which is already far too much for home use. But I think single core won't be enough with such high voltages. But you can stack them, so you have 2 cores for one inductor.
I have luch and I didn't have to buy the cores, but for such cores you should contact
Micrometals - Iron Powder Cores
and try to see, where you could get them, maybe even as samples
I FEEL SLOVENIA
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
IRS2092 Amplifier zox2003 Class D 22 31st August 2009 09:49 PM
Page generated in 0.09469 seconds (80.10% PHP - 19.90% MySQL) with 11 queries
