Producing Triangle Waves - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th September 2009, 03:51 PM   #31
nitrate is offline nitrate  United Kingdom
nitrate's Avatar
81Bas,
Hardly any ringing at all, See the waveforms earlier in the thread. They are very clean
The perfect amplifier is a piece of wire with gain....
Old 10th September 2009, 03:24 PM   #32
81bas is offline 81bas  Germany
Absence of the ringing with big deadtime under NO load says nothing for me. Please, try to give some load (say 2-3 amperes), so the body diodes will enable during the deadtime, and post the waveforms here.
Old 10th September 2009, 06:16 PM   #33
nitrate's Avatar
Deadtime is only 50n/s... I thought that was quite small LOL
There was no load tho... I'll load it up to 200W and see if it changes things, if it does i'll post the waveforms. I've burnt it in at full power for over 10min's before now and i cant remember seeing anything dodgey in the square.. i'll certaintly check for you tho..
Leigh
Old 10th September 2009, 06:38 PM   #34
Pafi is offline Pafi  Hungary
Now the switching is half hard, half quasi-resonant, the second half is hard, and seems to be very fast, so the fact that ringing doesn't appear gives hope to work well also at full load, but the slow body diode of IRF640 will make losses relatively high. With music and real speaker there won't be a problem, but a continuous full current test may show more. (And waveform will change significantly for sure.) BTW: What is the bandwidth of scope and probe? Yesterday I explored a strong 240 MHz ringing in one of my amps despite the switching was not really fast (30-40 ns rise and fall time).
What is n/s?
Old 10th September 2009, 07:04 PM   #35
Originally Posted by Pafi View Post
What is n/s?
It is obvious: nano/seconds
Old 10th September 2009, 10:48 PM   #36
nitrate's Avatar
LOL, n/s = ns ... just my dodgey wayZ of notation
Old 14th September 2009, 10:57 AM   #37
nitrate's Avatar
Ok,
Over the weekend i've had time to remove all switching PSU's one by one. I started by again removing the LT25XX switchin reg with a 12v SLA battery. No effect. I then replaced the low side DC-DC converter with Ni-cad memory backup battery's. No effect. I then romoved the last DC-DC converter. Also no effect at all on the whistling noise. Its definatly sensitive to having a finger near the cmos nand gates. Also sensitive to touching the low side fet. Apart from those two hot spots you can literally lick the board when its operating and have no effect on the whistle. It must be the main carrier some how getting back into the modulator.
I'm gonna put all the power supplies back to normal over the next few nights and think of somthing else. Very strange indeed. I may have to submit and go with self osc topology, or just close the loop and pretend its not there
Oh yeh.. Loading. When loaded up with a 4R resistive load and 1K sine the amp delivers full power at about +-42V Pk before cliping, 218W RMS, 7.4A Pk ( by calculation ). The only effect on the square is a 3V increase in overshoot spike. Nothing worth posting.
Has anyone any other thoughts on what can be causing the intermodulation noises? I'm about all out of ideas
Leigh
4780 producing only hum: help needed! zenocosini Chip Amps 6 17th November 2005 04:27 PM
wich school is the best for producing ? hectik Everything Else 2 27th June 2005 07:00 AM
c3g producing sparks garbage Tubes / Valves 2 11th April 2005 03:03 AM
Tool for producing an LCR network that = a speaker+box? CeramicMan Multi-Way 2 27th May 2004 02:39 AM
Copyright 1999-2017 diyAudio
