class d with multiple rails class d with multiple rails - Page 2 - diyAudio
Old 3rd September 2009, 09:29 AM   #11
luka is offline luka  Slovenia
luka's Avatar
am yes you can, TA105a, or TA2500 from tripath, I think you could make 4kw amp
Old 3rd September 2009, 12:59 PM   #12
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
I am developing and planning to build something similar. Just one DC power supply without reference to ground, which becomes either negative or positive synchronously with the main half-bridge switching states. In terms of charges, Rdson and body diode, halving the Vdsmax requirements for mosfets is truly revolutionary to both distortion and efficiency.
Old 3rd September 2009, 03:51 PM   #13
MOER is offline MOER  United States
Default Multi-rail class D
We use variable rail switching in our class D mobile amplifiers.
Saves a lot of heat and also "helps" the MOSFETs
I have also designed a full tracking switchmode supply so one can then hang on a class D or a class B amplifier for ultimate efficiency
Steve Mantz
Zed Audio Copr.
Los Angeles CA
Old 3rd September 2009, 04:42 PM   #14
fredos is offline fredos  Canada
Just cascode some slow high voltage high current mosfet with fast low voltage high current mosfet! Dont forget recovery diode! That work up to 6Kw with +/-280V rail. In each half leg of your bridge, you use low voltage as standard mosfet and with the 12-15V supply of the mosfet driver, you simply feed the gate of the high voltage mosfet. In that way, the switching device never ''see'' more than 10-13V. I doo it with SMD high current mosfet, without heat sink! Nearly all lose pass trough the cacoded high voltage fet and recovery diode.
Old 4th September 2009, 01:02 AM   #15
Default Multi rail class D
The slow MOSFETs sounds interesting but it still must be switched.
My power supply tracks the audio waveform so I can keep "X" volts across the MOSFET
Steve Mantz
Zed Audio Corp
Old 4th September 2009, 04:01 AM   #16
Pafi is offline Pafi  Hungary
Let's have X=0, and you can make amplifier from a wire!
Old 4th September 2009, 04:55 AM   #17
Default Class D
Now this is what I call a real smart and constructive reply.
Old 4th September 2009, 02:24 PM   #18
nitrate is offline nitrate  United Kingdom
nitrate's Avatar
Originally Posted by wg_ski View Post
Those motor drives are already going to be operating at a low frequency compared to a class D audio amp. Any global feedback employed would be painfully slow, even for a subwoofer amp.
If you wanted to eke out more efficiency in a sub amp (or get away with slow MOSFETs) lower the PWM frequency first before doing anything more elaborate. A sub amp may be quite happy with 10-20 kHz and switching losses should fall dramatically and there would be no need for any rail stepping. Unless of course, you were using those big industrial FET packs, and putting out 50kW (100 hp). You're not thinking about running 20 lab horns off a single amplifier, are you?
100 Horse power subwoofer sounds good to me!
The perfect amplifier is a piece of wire with gain....
Old 4th September 2009, 03:34 PM   #19
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Those complex solutions look good... Until someone achieves similar or better efficiency and idle power consumption with a straight output stage
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th September 2009, 04:54 PM   #20
acid_k2 is offline acid_k2  Italy
Steve Mantz
Zed Audio Copr.
Los Angeles CA
I'm trying to imagine a SMPS modulated with audio signals... WITHOUT final stage (class D or class B amplifier).
Don't know if this thing exist, for audio application.
Maybe it's good for a subwoofer
class d with multiple railsHide this!Advertise here!
P3A on +/-12V rails 00940 Solid State 6 5th March 2008 12:44 PM
Multiple subwoofer/multiple amp question boogs Subwoofers 5 13th November 2007 04:36 AM
from +/-80v to +/-70v rails leander Solid State 14 13th September 2005 11:26 AM
Cap across rails? MikeW Pass Labs 12 24th August 2004 01:35 PM
Class AB car amp, switchmode power supply, what rails?? SkinnyBoy Solid State 4 8th December 2003 02:26 PM
Copyright ©1999-2017 diyAudio
