Go Back   Home > Forums > Amplifiers > Class D
Old 1st September 2009, 08:59 PM   #1
Default IRS2092 AMP help
hey
after my previous amplifier i want to make new one,with more power and with more sound quality.
as you see in my previous amplifier i didnt use any PCB and that was discovered as a big mistake because not all the time the boards were OK and it take a lot of time to constuct them.
now i am going to a PCB method or anything similar with the IRS2092. my goal for now is to make full-range amp with as much wats as i can get from ~80+- supply.
i use the excacly scheme from the datasheet:
http://i70.photobucket.com/albums/i1...Untitled-3.jpg
and here is the PCB
http://i70.photobucket.com/albums/i1.../Untitled1.jpg
(this is without inducator because i didnt find any right footprint .. and also with thick coper,i dont know how to change)
i am probably doing something wrong..
there is some compoments need to be specialy close?
and there is any other cheap PCB out there for this chip?
in batchPCB my PCB cost around ~25 $ and with the inducator probably more.. this PCB can be cheaper?
http://www.diyaudio.com/forums/attac...7&d=1251741489
thanks
Old 2nd September 2009, 07:48 AM   #2
SNY is offline SNY  Hungary
Default pcb
Excuse me, but my English weak.
Built pcb's price $200 (see pictures). (2) Dual Mono.
High Quality Elna Cap's, Carbon film resistors ...
Parameters same as the ref.design, or better.
Single Layer PCB.
Old 2nd September 2009, 02:34 PM   #3
my English is weak too,as long as i can understand you its fine for me
from what i understand from you is that the coast of 2 PCB with or without the compoments(?) is 200$
if with the compoments what is the price for only the PCB?
Old 29th January 2010, 03:29 PM   #4
That board layout is not good, as APP note of IRS2092 telling us we must have copper on top, and three poligons, one is floating input, secound ground and third one bus of supply if I'm write.....so 2 layer board is necessary, and as there is little components you can make it by you're won, it won't be expencive.
Class-D Amp with IRS2092 mag Class D 179 16th December 2011 04:41 PM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 10:10 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 08:25 PM
IRS2092 Amplifier zox2003 Class D 22 31st August 2009 10:49 PM
Any suggestion for IRS2092 ja2dhc Class D 4 2nd August 2008 11:53 AM
Page generated in 0.08848 seconds (76.63% PHP - 23.37% MySQL) with 10 queries
