| Class D Switching Power Amplifiers and Power D/A conversion |
Here is my situation:
I've got a very cute vintage Harman Kardon A401 integrated. But even if it sounds surprisingly good for something 30 year old, I'm considering replacing its internals for something a bit more up to date. The amp is rated for 2x20W continuous (it seems very conservative) and I'd guess the xformer is somewhere near a 100VA. I changed the power supply caps some times ago for a pair of 10.000uf/50V. The rails are at +/-28VDC. The modules I've been considering are based on the ta2022: - http://connexelectronic.com/product_...products_id/45 (but this module requires higher rails ?). - http://www.41hz.com/shop/item.asp?itemid=2 or http://www.41hz.com/shop/item.asp?catid=14&itemid=3 The TDA8920BTH seems also interesting: http://connexelectronic.com/product_...products_id/48 Two questions thus: - has anyone compared the ta2022 to the TDA8920 ? - will the xformer be sufficient for those modules, with 6 to 8 ohms speakers ? Thank you in advance for any bit of advice ![]() And because it's a little cutie:
Ben. |
#2 |
I recently bought a ConnexElectronics TDA8920, haven't tried it yet though as I'm still waiting for the 2x18VAC transformer to arrive.
Iv'e got the ConnexElectronics TA2022 the Toroidal I'm using with that is a 2x22VAC. It has a lot of power but the noise floor is a bit high. I'll let you know what I think when I get a TDA8920 up and running. col.
http://www.minirig.org.au |
#3 |
I have a few Tripath EB-TA2022 boards for sale if you're interested.
FS: (3) Tripath EB-TA2022 2x100W modules These include an onboard DC servo and output protection relay. I don't think those features are present on the ConnexElectronics boards.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 | |
Seems very interesting, use the old classic case with modern internals.
gychang Quote:
| Maplin 100W mosfet amplifier - power supply problem | HBrunt | Solid State | 8 | 21st October 2011 01:04 AM |
| Class D Power Supply??? | Co_Driver | Class D | 19 | 17th December 2010 01:05 PM |
| Class D Power Supply | kuda | Class D | 7 | 12th May 2006 07:58 AM |
| 12V 100W power supply- 120mV p-p ripple | Thunau | Power Supplies | 1 | 18th March 2006 07:43 PM |
| DC-DC Power converter for Class T amp power supply? | rtalk | Class D | 2 | 7th December 2004 04:02 AM |
| Page generated in 0.08822 seconds (79.80% PHP - 20.20% MySQL) with 10 queries |
