| Class D Switching Power Amplifiers and Power D/A conversion |
#71 | |
Once again, thanks. These are great, easy to use boards with a great form factor. They sound good and are very quiet. Terry
What we don't understand is called magic. |
#72 |
post 69: is input 2 connected to the correct end of Rf?
regards Andrew T. |
#73 | |
It depends on how much dc you have at the speaker terminals.. If the dc offset has been adjusted with those resistors in place and you remove them, you may then have worse dc offset. The dc offset trimmers I think are under the heatsink, so to re-adjust them the heatsink would have to be off. I don't know if the chips could cope with that? If you can measure the dc offset please let use know the figures. Barry.. |
#74 |
No... looks like the image was mirrored but not the opamp.....
Damn... why didn't I think of that! |
#75 |
#76 |
My 2 cents about Tripath Board 4*100W class-D ver 1.1
This is the equipment. Wallwart Switching PSU 24 Volts at 26 Volts. Tripath Board 4*100W with a 12 volts fan running at 5 volts on top B&W 685 BI AMPLIFIED DIY Lightspeed Passive Attenuator PC nforce 2 windows xp analog ouputs, ASIO driver , playing Mp3 and flac. This amp Sounds really clear, and with great soundstage, crystal clear compare to my yamaha HT 5.1 receiver. The only thing I don´nt like, is that the tweeters sound a little hard, and the music sound to technical. MI think that a Gain Buffer (tube or discrete) after the attenuator will help. Any opinions? ... |
#77 | |
Scott |
#78 |
I was running a feet long cable,now I change to a 3 inch long and there is a very hi difference in noise without source, almost disapear. I think the bass improve a little bit also. Next plan to solder to the amp. thanx a lot, any other idea?
#79 | |
Sure Electronics New Tripath Board tc2000+tp2050
Scott |
#80 | |
Worse, though, is that the capacitors used to replace R12,13,16,17 are tiny little monolithic ceramics. |
| Sure Electronics New Tripath Board tc2000+tp2050 | pincellone | Class D | 2233 | 11th February 2012 10:19 AM |
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 12:41 PM |
| FS: Tripath EB-TA4100 4-Channel Class-T Amplifier Evaluation Board | ralphs99 | Swap Meet | 7 | 16th May 2009 10:33 AM |
| Page generated in 0.08557 seconds (71.63% PHP - 28.37% MySQL) with 11 queries |
