| Class D Switching Power Amplifiers and Power D/A conversion |
#31 | |
#32 | |
I do like the look of their Class T cases too, very cheap and stylish, perfect if you need a pot in there. Steve |
#33 |
Why do you allow yourselves to be so easily conned?
Look at the datasheet for the tk2050. It is a 42W into 8r0 @ ~0.1%distortion amplifier. Not 100W. Look at the data and look at the graphs. The only version that approaches or exceeds 100W is the parallel into 4r0. That is TWO amplifiers operating in parallel to give 117W into 4r0, i.e. 58.5W into 8r0 @ ~10% distortion.
regards Andrew T. |
#34 | |
The Sure design is using parralled amplifiers. Its not a con. If you look at this image (heatsink removed) you can see the 4 stereo chips. i.e. 4*100W. Of course 100W is not an exact figure, and you wont get 100W per channel without serious distortion if at all. But it should be useable to around 60w. The 2 channel version sounds very good in stock form. Last edited by justblair; 23rd September 2009 at 01:47 PM. |
#35 |
The "Winsome Mouse" which uses the same chipset and a 30Volt PS is quoted as delivering 50 "clean watts" per channel. Mine certainly has sufficient power to drive the upper end of my OB's.
Pete |
#36 |
Hi Andrew. I don't think I am being 'conned' since I already knew what power I might be expecting into my 6-8Ω load. In fact I think I mentioned it earlier on in the thread. I used to have a Trends TA10.1 which I modified slightly, and I would guess that before any meaningful distortion I may have been getting around 7-8w maximum into a benign 8Ω 94dB load, so no issues there.
Is the power output the only point on which you believe we are being conned? or is there some other issue we need to know about? Do you have a preference for chip amps over Tripath? if so, any reasons? Thanks Andrew. Steve |
#37 |
I don't know if I have ever listened seriously and knowingly to a digital amp (of any type).
I do have a preference for discrete analogue over ICs.
regards Andrew T. |
#38 |
Thanks Andrew, sorry if my post appeared as if I was having a go, really I wasn't and I value comments from someone such as yourself with a wealth of knowledge and experience.
Steve |
#39 |
So anybody heard the board already?
#40 | |
I love my Clone, but the Tripath sound is even better IMHO. |
| Sure Electronics New Tripath Board tc2000+tp2050 | pincellone | Class D | 2233 | 11th February 2012 10:19 AM |
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 12:41 PM |
| FS: Tripath EB-TA4100 4-Channel Class-T Amplifier Evaluation Board | ralphs99 | Swap Meet | 7 | 16th May 2009 10:33 AM |
| Page generated in 0.09593 seconds (68.61% PHP - 31.39% MySQL) with 11 queries |
