Why am I blowing IRS20955's?
Old 20th August 2009, 06:29 PM   #11
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Lucky you I've blown about 2dozen of driver chips (but not this type) to learn to use them. I found out some practical points about using driver IC.
- Supply pins of the driver IC must by bypassed by ceramic smd caps as near as possible to the pins. If possible, use uninterrupted ground plane for connecting all ground points of a classD amp. Ground plane around driver IC not necessarily mean 0V plane, but can also be -VCC plane
- Gate resistor value. I also found out about 22ohm is good practically. But this R must be high-dissipation (0.5Watt or more, I use smd 47ohm//47ohm to dissipate heat). Lower than this may blown the chip, higher give bad square wave or difficult to control dead time.
- We must put capacitor (I use 470nF) right directly from drain lead of upper mosfet to source lead of lower mosfet (I use pin-to-pin connection, to minimize lead length). It's like a bridge hovering between D-upper to S-lower mosfet. Extra ceramic capacitor from upper drain to ground and lower source to ground makes it better.
Why am I blowing IRS20955's?Hide this!Advertise here!
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 10:44 PM
schematic for IRS20955 iwan_audio Class D 0 7th April 2008 07:29 AM
Blowing my fuse (s) Jimlondon Chip Amps 7 7th March 2005 07:03 PM
why do my tweeters keep blowing brsanko Multi-Way 39 25th February 2004 03:02 AM
blowing up my amp lilnigg99 Multi-Way 1 13th August 2003 11:38 PM
