Go Back   Home > Forums > Amplifiers > Class D
Old 12th August 2009, 04:53 AM   #1
Default T-Amp as FIRST soldering project?!
Hello there!
As my first every DIY audio project, I'm building some Munny speakers (should be crazy easy, link ).
I thought to spice things up I'd build it a matching T-Amp.
BUT...I've never really soldered....
So, how hard can this stuff be, and you have to start somewhere, right? The only kit I've found online is the one from 41Hz, but I hear that it can be somewhat challenging.
Do you think this would be a suitable project for me, someone who has never soldered before and can't really read an electric schematic?
THANKS in advance!
Old 12th August 2009, 07:10 AM   #2
berni8k is offline berni8k  Slovenia
Send a message via MSN to berni8k Send a message via Yahoo to berni8k
I dont realy recommend making one if you are so unexperienced in electronics.
Its best off to start with simple kits to lern soldering and especialy reading schematcs.
Old 12th August 2009, 07:20 AM   #3
Hmmm fair enough berni8k...
What kits might be better places to start?
I'd love to build up to making a T-Amp and some crossovers.
Old 12th August 2009, 07:23 AM   #4
Nanook is offline Nanook  Canada
Nanook's Avatar
Default about as simple as can get...
look at this kit from 41 Hz. only real challenge is soldering the chip to the board. Everything else is dirt simple. I made one (I reviewed it for Affordable$$Audio). All you have to do is go find a surplus 12V 3A laptop computer switching mode power supply, often available for little money online.
stew -"A sane man in an insane world appears insane."
Old 12th August 2009, 07:45 AM   #5
Thanks Nanook! I'm psyched.
Now for the REALLY noob question.
I will need:
1. Solder
2. Soldering iron
3. DMM
4. PSU
..that's it, right?
Thanks again pal.
Old 12th August 2009, 07:56 AM   #6
Those are all basic stuff yeah.
What i also recommend is a solder sucker. Its a round pen like thing that has a piston and a spring inside to suck up solder when its molten. Comes very handy for unsoldering stuff.
Old 12th August 2009, 08:14 AM   #7
Got it berni8k.
BTW Nanook, I'm assuming you meant the basic model?
Old 12th August 2009, 08:17 AM   #8
Yeah if you getting the stuff might as well get a cheep solder sucker since they only cost a few bucks and save you a lot of pain when trying to desolater something or fix a soldering opsie.
Old 12th August 2009, 12:19 PM   #9
Nanook's Avatar
Default ledhed....
Yes , I linked to the amp6Basic.
First off, a DMM is not required to build this kit. It is nice to have though. I bought an inexpensive Greenlee one, like this , years ago. As per usual, the leads fail , but that is a design flaw of virtually all DMMs and new leads are cheap!
Besides a "solder sucker (whether a "bulb" type or the spring loaded type) buy some copper wick . It can often help get very small amounts of solder off a board (and quite large amounts too). Once you use a portion, just cut it off and pitch it out (wherever you need to based on local laws, etc).
As far as a soldering iron (not gun, but a "pencil" type) goes, get the best one you can afford. Decent ones are as cheap as $20-$30, and upto $150 or so. Something in the 35-50 watt range is usually hot enough (too little heat can help you destroy circuit boards--I know I've done it '' ).
Also do a little research and practice a bit before making the kit ...
Reasonable deals for everything you would need can be had at Parts Express .
hope that helps. You will also need to decide on what to house it in...
Old 13th August 2009, 12:43 AM   #10
wwenze is online now wwenze  Singapore
Default Re: ledhed....
Interesting fact, but it makes sense after thinking about it - thermal resistance of a material determines tempereature difference between two points with a specific amount of power being applied at one end,
since the greater the power the greater the temperature difference between the two ends, a more powerful iron will heat the solder to melting temperature more quickly while resulting in a lower temperature at the other end, compared to a less powerful iron which will take more time and heat everything up.
But this is under the condition that the solder is heated until melting point only. If the two irons stay on the component for the same amount of time, common-sense can tell us which will become hotter and kill components more easily.
Thx for the warning btw.
soldering help! speedboy Parts 3 14th November 2008 04:04 PM
Digital soldering station project need help Tolik Equipment & Tools 0 12th January 2008 05:02 PM
soldering DIY IC rnzr Everything Else 2 24th March 2005 04:00 PM
soldering rulezzz Solid State 12 11th January 2004 05:11 PM
On Soldering vpharris Equipment & Tools 9 23rd April 2003 06:14 PM
Page generated in 0.12975 seconds (75.24% PHP - 24.76% MySQL) with 10 queries
