My very first Class D pwm (switching) amplifier. - Page 59 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th March 2006, 06:44 PM   #581
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
I'm sorry but what's the problem? I mean, what do you expect it to sound like when it clips? I'd say a good crackle is normal. Add clip protection or don't drive it that hard? If it comes out of clipping OK and survives I'd say good job.
Old 15th March 2006, 08:07 PM   #582
fehrudi is offline fehrudi  Hungary
Thanks for suggestion Pierre!
I think I found the problem.
The others side of 10k resistor (R7) on the SD pin is connencted to the COM pin on the PCB.
Later I removed that resistor and connected it directly. But that was wrong, because the SD pin is referred to the Vss.
So, when I shorted the resistor (R3) between Vss and COM, that crackle disappeared.
That crackle before was not normal. Lets say, that was something like blatter.
I only wanted it to crackle like a class AB amp (or at least similar to it).
I dont want to add clip protection unless I have to.
Old 16th March 2006, 06:27 AM   #583
Has there been any results on this from IR
Seems to run at a high frequency, self oscillation, not sure on how its done.
http://www.irf.com/technical-info/re.../iraudamp1.pdf
Old 16th January 2007, 01:16 PM   #584
mrx23 is offline mrx23  Hungary
Here you can find designing of a BCA amp with schematics:
it has NO dead time!-> minimal THD
http://www.diyaudio.com/forums/show...&threadid=94263
Old 16th January 2007, 01:25 PM   #585
lkadar is offline lkadar  Hungary
The correct link is: Redesign Crown K2/1 BCA amplifier (with schematic) pls help with the feedback
Old 16th January 2007, 01:41 PM   #586
Pierre is offline Pierre  France
Banned
mrx23,
Are you going to post the BCA schematics in EVERY thread in this forum?
Old 16th January 2007, 01:52 PM   #587
I am not that sure if the statement of BCA having no deadtime really holds¨!
Charles
Old 16th January 2007, 05:04 PM   #588
rogs is offline rogs  United Kingdom
It has always intrigued me why the designers of these amps choose such ridiculous values for some of the components -- on the 'main' pcb R246 is shown as a variable 10K resistor - and R245 is shown as 5.11K in series with it.
5.11K in series with a variable resistor!
I wonder how much else doesn't actually need to be there
Old 16th January 2007, 06:06 PM   #589
One reason the 5.11k could be chosen because the lower tolerance may also have better temperature stability.
Old 17th January 2007, 06:19 AM   #590
Are you wondering why there is a series resistor or why it is 5.11k ? There is a logical explanation for both of course. But before I give you the answer I let you think a little more !!
Charles
Copyright ©1999-2017 diyAudio
