My very first Class D pwm (switching) amplifier.
Old 17th January 2007, 08:42 AM   #591
rogs is offline rogs  United Kingdom
Unfortunately I don't seem to be able to access the schematic again at the moment, but from what I recall the variable resistor enabled the adjustment of a 'monitor' of some sort.
What I don't understand is why it is necessary to be able to vary between 5.11K (+ the tolerance of the minimum pot position) and 15.11K (+ the tolerance of the pot end position).
If the adjustment is likely to be around the variable resistance centre point, and within a range that is reasonably 'easy' to calibrate, then I would have thought 4K7 would have been perfectly adequate.
If you need to calibrate to within 10R (the present resistor is shown to 3 decimal places) how on earth do you 'tweak' a variable to that degree of accuracy (20 turn device?)
And why? -- if your design is that fragile, you've probably got it wrong!
Heaven knows what happens if the ambient temperature changes!!
I've obviously missed the point somewhere here!
Old 17th January 2007, 12:28 PM   #592
phase_accurate is offline phase_accurate
Depending on which series of resistors you use (and you better use what your company is using by default !) there is neither a 4.7k nor a 5.1 k resistor available if you want to achieve a tuning range of 5 to 15 k. So the nearest value is 5.11k !!!!
Simple as that !
Charles
Old 17th January 2007, 03:20 PM   #593
At my end of the pecking order, the purchasing people moan if they have to stock E24 values, let alone E 48, 96 or 192!!
And if I presented a design that could not accept a 4K7 to 14K7 range instead of a 5K to 15K range it would be thrown straight back at me as 'too fussy' !
Now if I worked a little higher up the scale----
Old 20th January 2013, 12:02 PM   #594
luizcpimenta is offline luizcpimenta  Brazil
Originally Posted by ssanmor View Post
Hello all again.
Here are the "definitive" version of my first prototype schematics. If anyone of you wants to have a look at them, any comment will be welcomed.
Meanwhile, I am ending the PCB design.
Thanks in advance.
Sergio
Good day Sergio.
Could you send me the final files?
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
Old 22nd January 2013, 10:50 AM   #595
manojtm is offline manojtm  India
manojtm's Avatar
Hi fehrudi,
not using SD then replace R7(10K) with jumber and R3(10R) not required short that point with jumber. cracking sound b'cause of SD point not good.
MANOJ
Old 25th December 2014, 04:19 PM   #596
stewin is offline stewin  Kenya
merry CHRISTmass to you all
My very first Class D pwm (switching) amplifier.Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
