AMP7 start to finish
Old 16th February 2010, 08:50 AM   #21
luka is offline luka  Slovenia
luka's Avatar
oh no, its know core, just BIG one, so I can have low freq, so that I max out 1mm wires on it... it has 6 turn primary and 20 some on secondary...its unregulated, just voltage limited... don't want to kill IC on amps
I would normaly go higher with freq. but since core is 63mmOD/36mmIN and 25mm high, with a lot of wire for primary and secondary, I have pretty damn rock hard output voltage, I only tested it for about 300w or so, since my moded PC supply wasn't to happy with 25A+ for any long period of time
Only battery could give me more, but that will be in car, since I don't really care how strong supply is, as long as it can hold voltage up for the amps to blast, that's fine by me
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 16th February 2010, 11:42 AM   #22
v-bro is offline v-bro  Netherlands
v-bro's Avatar
But what core material is it? The value and performance is not only related to size.
Yes, my lab supply couldn't keep up either! I had to get my 40A 12V supply out!
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 16th February 2010, 01:48 PM   #23
luka's Avatar
its 35G, from iskra feriti, slovenija, my home city, and 35G = epcos N87 and near match to ferroxcube 3F3
Maybe this will tell you more
http://www.classdaudio.co.cc/doc/Iskra/35G.pdf
I FEEL SLOVENIA
Old 16th February 2010, 02:17 PM   #24
v-bro's Avatar
Ah okay, that explains a lot, thanks!
Old 2nd March 2010, 02:42 PM   #25
luka's Avatar
Default Almost there
Yep yep, I am almost done, everything fine so far, here are few pictures
Click the image to open in full size.Click the image to open in full size.
oh and yes, its going to be controlled by microcontroller
Now I am waiting for PICKIT 2 to be available, I have already learned and done program for pic12f675, just need to program it and put is somewhere
I FEEL SLOVENIA
Old 24th May 2010, 07:08 PM   #26
luka's Avatar
Ok so, since I have already posted picture of heatsink (part of case) here, all end it also here. So today I finished wiring all of the amp, minus the output from amp's to case output terminals, I'll do that soon.. Amp's are both working, PIC is doing its job, and man, do they have some nasty power to give and all this was with current limited 130w supply, this should be insane in car with say, 80A fuse
I FEEL SLOVENIA
Old 24th May 2010, 07:13 PM   #27
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu
Nice work Luka ...
Congrats on the SMPS looks nice.
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 24th May 2010, 09:07 PM   #28
v-bro's Avatar
I designed my own board now, or actually, me and a friend did...
Old 26th May 2010, 05:19 PM   #29
luka's Avatar
Ok so... I got 3 pictures, not the best I could take, but will have to do for now, since camera died on me (is in process of ...)
If somebody will want more, I try to find some other way of taking picture...
Taken from power and output side
From the side...
Output...
There are some changes that will come at a later date, but now itsmore of a test time, see what everything works every single time, for now it is...
Still need to put(and change) heatsink on driver IC's and I'll probably change from resistive load to get some min duty cycle from smps, to HV buck converters, that will have power from output of smps, so that there won't be heat dissapated in resistor network
I FEEL SLOVENIA
Old 6th June 2011, 04:22 AM   #30
TheLaw117 is offline TheLaw117  United States
Hey Luka. Do you have the schematic for the transformer/power supply? Can I use your design but use a different amount of windings to get something like +/- 30V?
Looks great!
AMP7 start to finishHide this!Advertise here!
how to design a speaker from start to finish? space-cake Multi-Way 11 14th September 2007 01:23 AM
Start to a finish. jaudio Chip Amps 18 28th September 2005 01:00 PM
