Go Back   Home > Forums > Amplifiers > Class D
Old 29th July 2009, 07:49 PM   #1
gychang is offline gychang  United States
Default which volume-pot for amp D?
I see 2 major catergories linear/audio pot. Some have on-off switch built in.
which one is ideal for the usual t-amp clone?, alps is mentioned but price seem little high.
which one from here seem reasonable?
http://www.action-electronics.com/pots.htm
thanks,
gychang
Old 29th July 2009, 08:29 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
any? what is the big deal, its only a pot, nothing else
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 29th July 2009, 09:03 PM   #3
Saturnus's Avatar
Usually pots with built in on/off is much lower quality but if that is primary concern then an attunator, either with a rotating switch or a relay network is a much better solution.
Old 29th July 2009, 09:09 PM   #4
audio1st's Avatar
None of them seem suitable.. They are all mono.
You need a single turn, dual log, of a value between 10k to 100k.
Old 29th July 2009, 09:35 PM   #5
Saturnus's Avatar
Wouldn't a 10K only give a 1.5dB dampening with a standard 1:1 resistor network? I'd say at least 50K Ohm.
Old 29th July 2009, 10:32 PM   #6
I thought was strange only one row of 3 prongs...
thanks,
gychang
Old 31st July 2009, 10:58 AM   #7
col is offline col  Australia
col's Avatar
search these forums for "jaycar pot".
col.
http://www.minirig.org.au
Old 5th August 2009, 02:24 PM   #8
rhing is offline rhing  United States
rhing's Avatar
Default Bought this 50k SMD stepped attenuator on eBay
I bought a 50k log stepped attenuator from "tube_buyer" on eBay, and installed it on my Virtue Two Class D integrated amp. It has a nice solid feel and takes up very little space. It has the same footprint as a Noble or PEC pot. This little attenuator made a significant improvement in the sound quality over the stock volume pot in terms of transparency and improved frequency response. For $10 +$8 shipping, it was a great investment.
Rich
Old 5th August 2009, 10:24 PM   #9
col's Avatar
Hi Rhing,
That sounds quite interesting. Is it the same as this:
http://cgi.ebay.com.au/DACT-Type-21-...3286.m63.l1177
I could not find "tube_buyer".
cheers,
col.
Old 5th August 2009, 10:52 PM   #10
rhing's Avatar
Hi Col,
It looks like the same SMD stepped attenuator to me. These guys could be the same sellers under different names. Their ratings are identical.
Here's a link to tube-buyer's stepped attenuators and pots on eBay:
http://stores.shop.ebay.com/Parts-an...34Q2ec0Q2em322
I just soldered some stripped solid core hook-up wire segments to the pads on each PCB of the stepped attenuator to create pins for soldering to my Virtue Two's PCB thru-holes where the stock volume pot was connected.
No pops, static or any noises from my unit. It sounds great.
Rich
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Box Volume is Box Volume, right? skooter Car Audio 5 4th November 2008 05:17 AM
set volume with 50k Pot on Zen V4 cHab Pass Labs 2 17th June 2008 12:49 PM
volume pot william1981 Solid State 5 25th February 2007 10:31 PM
Box volume eitanwaks Multi-Way 7 19th April 2005 02:45 AM
Page generated in 0.10338 seconds (77.76% PHP - 22.24% MySQL) with 11 queries
