Go Back   Home > Forums > Amplifiers > Class D
Old 28th July 2009, 01:49 PM   #1
lhgin is offline lhgin  Malaysia
Default Connexelectronic TA2022 amplifier with FE167E (94dB/w/m) opinion?
Hi guys,
I'm planning to get the TA2022 Class-T Tripath amplifier module and use it with my Fostex FE167E speaker. Since the speaker is pretty high in efficiency, will it give me any noise issue?
I read from the CNX audio thread that a few have had problems on high noise floor on the module and I'm a bit worried if that would be an issue for my setup.
I heard that CNX had respin the module and it is much better now. I'd like to get feedback from the forumners here if anyone has tried the new version and has no problems on the noise.
Thanks!
Rgds, ken
TA2022 amp from Connexelectronic
Old 31st July 2009, 07:11 PM   #2
Hello,
While I can't vouch for the noise level when using the Connexelectronic TA2022 with speakers as sensitive as you describe, I can certainly recommend the amplifier for use with speakers of lower sensitivity (in my case, AR-90 & AR-91 @ 87dB), when coupled with a suitably robust high quality power transformer.
Shortly after receiving the kit from Cristi, I commented thus:
"I've rigged up a basic 'breadboard' quick-test set-up, and I must say that you have done an excellent job with this board, it is considerably better sounding than the Tripath evaluation board (EB-TA2022 Ver 1.6) that I tried previously. The sound quality really is excellent, and the amp is as quiet as a mouse, regarding hum and hiss etc., very good work!"
That was back in March, and four months later I stand by those comments, regarding the quality. I also have a PopPulse t150 (which is TA2022 based), and it too is a superb performer, good overall value if the DIY TA2022 route is not for you.
I've found no noise-floor issues with either amp, but one caveat: both do radiate RFI noise. This is apparent when listening to FM radio in stereo, especially on the lower end of the band, which (in the UK) affects quality broadcasts like Radio 3 & 4, so plan your reduction/shielding measures accordingly.
Hope that helps.
Robert_S
Old 2nd August 2009, 03:24 PM   #3
Thanks Robert. Your comments does help!
Old 3rd August 2009, 04:30 AM   #4
ttan98 is offline ttan98  Australia
Try Sure Electronics, TK2050(2*100W version), with 30V DC power supply you get about 50W continously into 8 ohms, plenty of reserve power. I have one playing now.
I use both laptop power supply @19.5 V and battery operate at 24V, the latter sounds so much better. NO NOISE at all at the output. Overall recommmended.
Old 3rd August 2009, 05:24 AM   #5
Thanks for the suggestion. I'll get it.
Is there any noise perceived with the 19.5V SMPS? I'm thinking of using one SMPS with some bypass caps + storage caps to keep the weight and size down.
Old 3rd August 2009, 05:34 AM   #6
No noise. A 0.1uF(by HF) and added 10,000Uf would improve the bass further.
TDA8920 TDA8924 By Connexelectronic, Opinions Please. cirrus18 Class D 51 20th December 2010 09:17 AM
HLLY TAMP-90 90W Class T AMP AMPLIFIER Tripath TA2022 hllyelec Vendor's Bazaar 2 19th January 2009 01:16 PM
Opinion about this hi-fi amplifier viktor1986 Solid State 31 15th November 2006 02:12 PM
Opinion about Legendino-6 amplifier viktor1986 Solid State 4 30th April 2006 05:20 PM
Your opinion about Amplifier sim. Dori Solid State 13 4th March 2005 01:23 PM
Page generated in 0.13809 seconds (49.46% PHP - 50.54% MySQL) with 10 queries
