Go Back   Home > Forums > Amplifiers > Class D
Old 21st July 2009, 07:01 AM   #11
berni8k is offline berni8k  Slovenia
Send a message via MSN to berni8k Send a message via Yahoo to berni8k
Yeah they are samples, they just released this chip recently so its hard to find in a store.
Oh and nice to see someone else from Slovenia here.
Old 21st July 2009, 07:11 AM   #12
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
hehe and we are not the only ones on here
I think I will like this IC, I can see it as car amp, hmm
Hope it will work out for you, maybe there will be something to look into later on
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 21st July 2009, 07:19 AM   #13
If you can make a nice switch mode for it it would be a great car amp since it only needs a single supply 20-50V to work.
Oh and i looked trough your page and you made some nice amp and switchmode projects. It gave me a toght to build a switchmode my self. Right now i use a huge, heavy as hell toroid.
Old 21st July 2009, 07:36 AM   #14
luka's Avatar
Yea go for it, they are pretty simple, I had one for my first car amp, powering LM3886 @ +/-30v, that was cool and all, then I wanted something from Tripath [there were other amps, all AB], since this is PWM amp, so I got myself AMP2 from 41hz.com and made a bit too huge supply for it, so now I'm looking into getting AMP7 also
But this little IC, if it does what they say, it could be something use for highs in car [for normal users, whole set of front speakers]
Will see how this will turn out, so far I like it very much
As for you, yea try 12v smps, something small, say one from Risto80 on this forum, that was my first smps, working great and simple to study what is going on, what is important and what not so much
I FEEL SLOVENIA
Old 22nd July 2009, 07:25 AM   #15
I assembled one channel of the amp and it dosen't work. Fist thing i found out was that i left the shutdown pin floating, fixed that and still wont make a sound now trying to find a solution
Old 22nd July 2009, 07:26 AM   #16
And the bottom
Old 22nd July 2009, 07:38 AM   #17
luka's Avatar
I don't know if it is ok for other outputs to float too
I FEEL SLOVENIA
Old 22nd July 2009, 10:05 AM   #18
Oh misunderstood the shutdown pin its a output to indicate device is not in a error state and it is 0 meaning the device is shut down and dose not react to the reset signal.After some diging in the datasheet i found that the SD pin remains low no mater what when the device is preforming the so called PPSC (Pin to Pin Short Circuit protecion) and is Dependant on the output inductor... hmm the inductance of a open cirucit is something like infinite uH that means i have to wait infinite seconds for the amp to complete the procedure.... i dont think i have that much time.
Anyway this means i have to build the 2nd channel too.... damn where to find those bootstrap caps.
Old 22nd July 2009, 11:01 AM   #19
luka's Avatar
what kind are they? if smd is problem, then ok, but any cap will do
I FEEL SLOVENIA
Old 22nd July 2009, 11:29 AM   #20
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
This PCB is missing a ground plane, don't expect it to work reliably in the higher supply voltage range.
I use to feel like the small child in The Emperor's New Clothes tale
6W, Class A, hopefully something I can build. :D keantoken Solid State 96 27th January 2011 11:28 AM
Help me Build a Class D alijoorabchi Class D 6 25th November 2006 03:19 PM
i want to build an 400WRMS class d amp avner31 Car Audio 3 21st July 2006 03:57 PM
Copyright ©1999-2013 diyAudio
