Class D amplifier help
Old 7th July 2009, 09:50 PM   #1
yellowblue1909 is offline yellowblue1909  Canada
Default Class D amplifier help
Hi all,
I am building a class D audio amplifier using the following parts:
LM311 - comparator
IR2010 - gate driver for the mosfet pair
This is the data sheet for the IR2010
http://www.irf.com/product-info/data...ata/ir2010.pdf
I am unsure what the input for the IR2010 would be..
Old 7th July 2009, 09:54 PM   #2
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
Do you have a schematic?
The 2010 is basically just a level shifter so you can switch the gate of the high side FET.
How are you generating the 2 PWM streams?
Old 7th July 2009, 11:21 PM   #3
as i can see from the data sheet, there are 2 inputs - LIN , HIN for the IR2010. However, I just have one pwm stream. I am generating this stream by comparing my input signal (i.e. audio) with a saw-tooth waveform using the LM311 comparator chip.
I did not know that there were 2 PWM inputs required... how do I get the second PWM input and why is it required.
Old 7th July 2009, 11:43 PM   #4
usually, there's a dead time at each transition so that the on FET turns off before the off FET turns on. It takes longer to turn the on FET off than the off FET on. This means that at low level (input to driver) the PWM stream is almost identical except for dead time gaps.
Hence upper stream is different from lower stream.
Oh, and the high side is inverted. Does the driver do that for you?
Old 8th July 2009, 02:54 AM   #5
hmmm .. thats interesting .. i was not aware of this ..
how would i generate the other PWM stream (with the dead times)?
I noticed that some comparators like the LM361 yield two outputs... so if i decide to switch my comparator from the LM311 to the LM361 can I just feed in one of the outputs into the HIN and the other into the LIN without actually having to generate another PWM stream?
Old 8th July 2009, 03:29 AM   #6
sawreyrw is offline sawreyrw  United States
yellow,
Given your questions you need to do your homework on Class D, before you try to build anything.
Rick
Old 8th July 2009, 04:03 AM   #7
Yes, read a book or two.
Can anyone recommend an authoritative text?
I'd be interested myself.
Old 8th July 2009, 08:35 AM   #8
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
One of possible solution for dead time generator and symmetrizer with some intentional time delay.
Input at transistor's base, 2 complementary outputs with adjustable dead time.
http://www.diyaudio.com/forums/attac...amp=1208267656
P.S. There are gate drivers with just one PWM input, like IR2104, but for class D amplifier you should have much lower dead time, possibly adjustable.
Old 8th July 2009, 02:21 PM   #9
Yeah I will refer to books.
I am an EE undergrad student and took this project upon myself for educational purposes. My goal is to get a functional class D amplifier and in the process realize how the various components work with each other.
Old 8th July 2009, 02:33 PM   #10
I don't know of a good book, but you should look for application notes from companies that make class D control ICs.
Class D amplifier helpHide this!Advertise here!
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 10:25 PM
Class A Amplifier Jean-Paul_2 Solid State 22 21st June 2009 02:36 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2017 diyAudio
