| Class D Switching Power Amplifiers and Power D/A conversion |
Plan to install this Power Supply (3.5Amp) inside TA2020 amplifier. Since this is first time I want to do this correctly.
1. I assume L, N are AC connection, is N stand for "neutral" or ground?, L is "hot" (wider blade)? 2. Usual inside DC jack connects to V+?, and the outside is ground? V- in my case is left unused?. 3. I will use the vol adjustment screw to get it to 13V in my case. Am I doing this correctly? thanks, gychang |
#2 |
From left to right:
1 - Line, 120V "hot" (black wire) 2 - Neutral (white wire) 3 - Ground (green wire) 4 - Negative DC voltage, this is the DC ground in your case 5 - Positive DC voltage Yes, use the pot to adjust the voltage. Use a multimeter to verify everything before connecting to your amp. Careful powering up a SMPS with no load, some do not take kindly to that.
The power of Science compels you! |
#3 | |
No load means, I should not turn on the PS without DC all connected? What is SMPS stand for? gychang |
#5 | |
I don't have a taillight bulb, any substitues? gychang |
#6 |
Salvage a lamp assembly (not a headlight) from an abandoned car? Like an interior courtesy light, dome light, or exterior clearance light off a truck or van.
Gas stations, auto parts stores, hardware stores, megastores are likely to have the 1156 and 1157 bulbs (and other small 12V bulbs). You can solder directly to the lamp base if you don't have a socket. They also make good tweeter protectors (wired in series) when your speakers are used with high power amps and you aren't in control of the source material. |
#7 |
what is the pros and cons of having the 3-green wire used. Some stereo components frequently omit the 3rd wire.
Is this for the extra margin of safety or "necessary" with amp D. gychang |
#8 |
The Ground (green to earth wire) is required for safety. It connects the metal case to ground. this type of Power supply should not be used without a ground connection.
Some amplifiers and other products do not have a ground wire. in these cases the item is designed to prevent access to any metal parts which can carry a fault voltage. The method is known as double-insulated and the case will be marked. See Appliance Class This is a fair over view othe the types (your Powersupply is a class 1 device. |
#9 | |
gychang |
| Help needed - Connecting Aux Voltage (HG Supply) to UCD400AD Ver 6.1þ | taykg | Class D | 0 | 2nd June 2009 02:02 PM |
| connecting a switch mode power supply | peace brainerd | Parts | 5 | 24th April 2008 11:32 PM |
| Connecting the power - Why does it look this way? | Tintin | Chip Amps | 10 | 26th May 2007 11:48 AM |
| any ideas for replacing the steel (cheap!) jumpers connecting pre to power in nad amp | nad freak | Solid State | 5 | 18th July 2004 03:41 AM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.10862 seconds (81.27% PHP - 18.73% MySQL) with 11 queries |
