| Class D Switching Power Amplifiers and Power D/A conversion |
I am a novice but with basic soldering skill and willing to learn.
I am trying to hook up non-illuminating power on switch ((A), has 3 prongs one with "copper" which I assume is ground) and a separate power on LED bulb. 1) is the picture correct to connect A to the board, B is obviously DC input. 2) do I need a extra resistor to connect the LED? (some web site suggested LED must be used with a resistor??) 3) does the polarity matter, one has a longer "leg". 4) can anyone direct me where to solder the LED on this board so when I switch A on the warning light comes on? thanks, gychang |
#2 |
If it is a non illuminating switch.
#3 | |
You have been a tremendous teacher with your clear pictorials, this is another. Even drew in a longer leg on LED... What is the third "copper" lead for? gychang |
| TDA1543 DC connect to TA2024 amp | jkeny | Digital Line Level | 26 | 25th August 2009 06:00 AM |
| how do you connect the ground of power supply to the plug of ac ???? | prorms | Power Supplies | 11 | 24th April 2008 12:13 PM |
| connect power to an op amp (dumb)? | Pbassred | Chip Amps | 18 | 28th May 2007 07:58 PM |
| How to connect electrostatic shield of power transformer? | bee696 | Tubes / Valves | 4 | 23rd July 2005 10:54 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.07335 seconds (68.82% PHP - 31.18% MySQL) with 11 queries |
