Go Back   Home > Forums > Amplifiers > Class D
Old 19th June 2009, 07:58 PM   #1
Send a message via MSN to gadgeteer123
Default hifonics BXi 1606D burnt resistors???
I have a Hifonics BXi 1606D Super class d amp, that has roughly about 10 blown/burnt resistors, i'm capable of replacing these, i just have no clue on what i need to order, the numbers next to the resistors are-R25E1, R26E1, R27E1, R28E1, R29E1, R30E1, R25E, R35E, R26E, and one that i cannot read, and a couple of the mosfets are cracked right by these resistors. so could you help me figure out which parts i need.
Old 20th June 2009, 08:48 PM   #2
so can anyone help me on this, i have seen the exact same problem on the 1202d model on this forum, and u where able to help him find the parts he needed, but i'm sure those parts won't be universal, if they are that'd be great, but idn???
Old 24th June 2009, 10:50 PM   #3
i know this is my second bump, but can't anyone help me please, i just have no clue to what mosfets or resistors i need.
Old 27th June 2009, 01:20 PM   #4
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
Default If
If they are on power switching stage (SMPS) , the transistors must be N-MosFet, and could be used IRFP064N or IRF 3205, depending of capsule of transistor.
The gate resistors are between 10 and 22 ohms, I always used 10 ohms.
If they are on ClassD Switching amplifier, is a little more complicate.
Must be replaced ALL mosfets and all gate resistors.
Also check ,or better replace TL494 or SG oscillator circuit, also eventually buffers,before powering on.
First,try to use a small 5-10 amps fuse for testing, seried with power supply, if is ok, then replace with bigger valuie, till approaching the oficial valor of it..
Get us a bigger an CLEAR photo, (macro is ok) ,it could be better for hepling us ,to helping you.
Good Luck!
Old 28th June 2009, 12:31 AM   #5
ok, here are the better photos, its the best i can get right now, since someone stole my digi-cam.
Old 28th June 2009, 12:31 AM   #6
second pic.
Old 29th June 2009, 02:09 PM   #7
Dimon74 is offline Dimon74  United States
All gates resisstors is 47 Ohm 1/4 watt,mosfets in this amp is usualy FQP65N06 .You can install IRFZ48V,they are even better then original ones.100% driver transistos blown too.They are located between toroidal transformers.They are two pair of KTC3228 and KTA1275 .Cheapest replacement for them is BD139 and BD140
Old 30th June 2009, 08:55 PM   #8
Default Yes
Yes, looks to be SMPS switching part.
Try to replace (ALL) mosfets with IRF3205 if they are in TO220 Case, or with IRFP064N if they are in TO247 Case.
The buffer transistors are perfectly replaced by ZTX 851 and ZTX 951,or if you don't find em, could try BD 237 BD238.
Also replace the TL494 or SG 3525 on oscillator stage!
Use 22 ohms /0,6 watts for gate resistors.
Good luck and let us know how you managed'em!
Hifonics Bxi 1606d Please Help dmeche Class D 3 25th July 2009 07:15 PM
Carver MXR130 Receiver Burnt Resistors DreadPirate Solid State 2 13th March 2008 03:18 PM
burnt resistors on speaker output? jol50 Car Audio 7 5th December 2007 04:02 AM
burnt resistors on PPI PCX-1250 cutlass1991 Car Audio 9 19th September 2006 10:38 PM
Help! resistors burnt after capacitors replacement overmind Everything Else 7 15th May 2003 10:09 PM
Page generated in 0.10959 seconds (70.73% PHP - 29.27% MySQL) with 11 queries
