Go Back   Home > Forums > Amplifiers > Class D
Old 19th June 2009, 05:55 PM   #1
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Question SMPS Requeriment for Class-D
Hello,
I'd like to know what are the power supply requeriments for a R.M.S. rated Class-D amp.
For example, for a 90% efficient 100W R.M.S. amp, how many watts should my SMPS deliever?
Looks obvious that it would be 100W + 10%, but as I know, music will never, ever drain this much power.
I've been sucessfully using a 360W R.M.S. amp witha 240W SMPS!
I'd like to have your opinion and see some calculations
Thanks!
Old 19th June 2009, 07:27 PM   #2
wg_ski is offline wg_ski  United States
I seems to be common industry practice to size the power supply for current demand at 1/8 power with pink noise at nominal (not minimum) load impedance. That's for any amp regardless of class. High end professional stuff (Labgruppen, Crest, Powerlight) is designed with a bigger supply, but not the entry-level stuff. For home use you don't need much more, but the amp will have *better bass* if the supply can put out full peak current (Vcc divided by minimum RL) for at least the short term without going into a current limit mode. For larger amps, that can be a tall order.
Old 19th June 2009, 09:17 PM   #3
ssanmor is offline ssanmor  Spain
It all depends on the kind of music you listen to, the long term power required and how tolerant your PSU is to overloads, but for serious equipment I wouldn't recommend less than the total power you require, (1000W-continuous-capable PSU for a 2x500Wrms amplifier, for example, assuming that it is Class-D), in order to be on the safe side and have lots of power reserve. You can hear lots of arguments trying to justify less, but that is simply skimping, with a detrimental effect on reliability and sound quality.
Old 19th June 2009, 10:21 PM   #4
Yeah, it's for professional use.
Actually, it will have three amplifiers of 700W R.M.S. @ 8Ohms, two driving two woofers (one for each) and another one sub-utilized (no need for 700W, but it's just easier to use the same amp) for the compression driver.
I'm thinking of two 700W continuous power supply's, one for +V and another for -V. Amplifiers will be fullbridge, so no concern about pumping effect!
Am I being exaggerated?
Best Regards!
Old 19th June 2009, 10:35 PM   #5
Pafi is offline Pafi  Hungary
Since music signal is not constant, you shouldn't determine continous output, but peak power, and average powers for different duration. Peak power consumption can be 3-4 times more then rated power, but average power is fraction of that.
Some PSU can be overloaded very much for a short time, some of them limit their current if nominal power is exceeded, some of them shut down (etc...). You have to know what your PSU does under overload condition.
Old 20th June 2009, 08:12 AM   #6
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
There's a couple of slides about this topic in Bruno Putzey's electronics presentation (find it on the hypex website). IIRC it's something like: PSU current limit of twice the max peak current across the load and: PSU continous power (thermally limited) of between 1/3th and 1/8th of the max power consumption (= full output power / efficiency at full output). 1/8th power is typically enough for consumer applications whereas 1/3th would be the spec for PA amps.
Note: I am going from memory so check these numbers for yourself
/U.
SMPS for class D module NewTesla Class D 40 16th May 2010 07:38 PM
SMPS vs. Class-D. Dag Class D 17 2nd March 2007 05:23 PM
A cheap 12v SMPS for class D Foxx510 Class D 0 22nd December 2006 07:55 AM
JLH class a with a SMPS?? Possible? DJNUBZ Solid State 2 27th March 2005 04:47 PM
help with class D amp and SMPS Evan Shultz Class D 9 23rd February 2005 12:36 AM
Page generated in 0.08836 seconds (76.46% PHP - 23.54% MySQL) with 10 queries
