Go Back   Home > Forums > Amplifiers > Class D
Old 19th June 2009, 05:19 PM   #1
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
Default New ClassD project Starting from 0
Hi, I decided to start my new ClassD project.
It will work for bass only,20Hz-200Hz
Oscillator with 4 Mhz ceramic resonator, MC14060BCP oscillator and divider, on pin 5 exactly 100Khz.
Here is some pictures of trianglegen output, measured wth a 20 Mhz scope
On pin 5 output:
On trianglegen output:
Is this correct?
Old 19th June 2009, 06:17 PM   #2
Default I
Being enthusiasmed, I forgot to mount the operational on soket
Now, on output, the signal is like this:
The schematic is that:
Any opinions?
Suggestions?
Old 19th June 2009, 07:16 PM   #3
wg_ski is offline wg_ski  United States
Well, so far so good... but generating a triangle wave is straightforward. What you'll see around here is mostly kits and one-chip wonder solutions because it can get hairy further down the rest of the chain. What will be really interesting is what you come up with for a dead-time generator, and how you couple the gate driver circuits from the low-level PWM signal into the bank of hexfets.
I'm looking at class D architectures for bass as well. Starting with the output H-bridge, with optically-isolated gate drive (like Crown CE4000, but I'm not doing BCA). Once I nail down how fast this thing can reliably switch, that will determine what kind of dead time and carrier frequency it can handle.
Old 19th June 2009, 10:10 PM   #4
Default Excuse
Excuse me, at output triangle gen and oscillator, is 125Khz, not 100, how I wrote and put on schematic(I was thinking at something else ...)
On LM361 outputs, I obtained those signals:
Old 20th June 2009, 02:42 AM   #5
100kHz... 125kHz... what's the difference? I just figured your scope was out of calibration.....
Old 20th June 2009, 01:37 PM   #6
With 4 Mhz Crystal, you will obtain 125 Khz divided, not 100 Khz, my blame for thinking at other things whan I wrote...
Possible the scope being decalibrate...
I will check.
Old 27th June 2009, 11:34 AM   #7
Default I'm back
I'm back, it's a full bridge configuration, it works !
For 125 Khz switching, how many uH must have the output coils ?
I tried with 80uH for low side, also for Hi side too, and everything is COLD.
No coils warming up and no mosfets too, in IDLE, they rest around 35-40 celsius degrees maximum, and around 55 degrees in load, delivering 33Volts RMS on 4 ohms load, with 56 volts supply.
I will come later with some screens.
Old 27th June 2009, 06:36 PM   #8
Default Some
Some pictures and movies.
It works perfectly at 125Khz, I have an output , only 130 milivolts residual of 125Khz switching freq.
Supplied at +/- 30Vcc, it gives around 350Watts on 4 ohm, with more than 90% randament.
All is in studying stage, following improvements.
Is done with P and N mosfets, on output, next modification is to use only N mosfets.
Any sugestions?
Triunghi:
(links removed by mod due to their inappropriate content.)
Old 28th June 2009, 10:00 AM   #9
Default Also
Also, first movie, I put again, because first link was bad...
(link removed by mod for inappropriate content)
Excuse support of the site(litlle nasty),and download it.
Old 28th June 2009, 11:33 AM   #10
+/- 30 volts power supply??
That should give no more than about 20 V RMS, which is 100 watts / 4 0hm.
Am I missing something here?
Pieter
Starting new project on ETON goodspeaker Multi-Way 5 7th February 2009 08:18 PM
Starting project needed... keantoken Everything Else 4 28th October 2006 11:19 AM
Starting a buffer project enter Chip Amps 7 13th April 2006 06:38 AM
Starting my first project. sachi Multi-Way 71 18th August 2005 11:52 AM
Page generated in 0.10598 seconds (83.22% PHP - 16.78% MySQL) with 11 queries
