| Class D Switching Power Amplifiers and Power D/A conversion |
#161 | |
Classically Itech series amplifier of Crown wich says safe loads of 1-2-4-8 ohms on each channel... How they do that? |
#162 |
They designed it to 1 ohm, then apply feedback after the filter.
But since you build a sub amp, pre-filter feedback, you don't have to design the filter this way. Trust me! ~20 uH is a good value, but there is no equation to calculate it! Against ringing, you can use an RC damper in parallel with output. Rl+C3. C3=2 uF is enough, there will be more residual, but it doesn't matter at all! (But you have to use polipropilene foil capacitor!) Ouroboros! This is a sub amp, operating at 125 kHz! Why would you set fc=35 kHz? |
#163 | |
And, if I want to modify feedback to be Post Filter,what will be the difference? Presumimg I want to transform that amp in a fullaudio amp? Carrier will be by ex 250 Khz, for full audio, I think it's enough... I observed on Crown K2, is post filter feedback, and they used triangle carrier on pin 3(+) input, instead mine wich is on pin 4(-) input... |
#165 |
Good one Stinius - thanks!
#166 |
Excelent link,thank's Stinius!
#167 | ||
Series connection as in the linked page can also work, but that is more expensive, and bigger (because you need twice as much capacitance for the same result). Quote:
#168 | |
#169 |
So, I received from the producer, exact parameters of mine Dark Blue Cores :
G1W 88S540 : ![]() ![]() What's your opinion? Is or isn't , suitable for classD Output filter? Can anyone tell , for 20uH, at how mant amperes it will saturate? Also I can buy some of these cores: Cores in material grades: N (60ui), Z (125ui), S (140ui), NH (60ui), ZH (125ui) SH (140ui). So, wich will be the best for classD inductors? |
#170 |
Core saturation is a function of amp turns. Inductance is a function of Al. So for a desired inductance and peak current, find a core with a suitable Al and NI (amp turns) rating. Cores with lower Al have higher saturation NI capability.
| Starting new project on ETON | goodspeaker | Multi-Way | 5 | 7th February 2009 08:18 PM |
| Starting project needed... | keantoken | Everything Else | 4 | 28th October 2006 11:19 AM |
| Starting a buffer project | enter | Chip Amps | 7 | 13th April 2006 06:38 AM |
| Starting my first project. | sachi | Multi-Way | 71 | 18th August 2005 11:52 AM |
| Page generated in 0.11676 seconds (79.58% PHP - 20.42% MySQL) with 11 queries |
