| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
Sorry just one other thing. When tracing around the RCA input, do i keep my earth probe (well crocodile clip) attached to the RCA shield the entire time or do i put it onto the earth of the amplfiier?
#22 |
if you look for signal, then I would say keep it on input gnd at all times, since input signal is input
#23 |
Ok, cheers.
I'll post back later with my results of following the input around. I was hoping it would be something more fundamental though, as the power light isn't coming on... |
#24 |
it still could be, like led driver, but since you don't get no sound and we don't even know if output stage is working... we can't say more then this for now
#25 |
Ok, so i need to put the scope across the output fets when the amp is on and there is an input from the RCA's.
Then if get nothing, re-think. .Thank you again for your help. I'll post back with scope results. Also some better pics if needed. |
#26 |
no no no, why would you look output with input??
input is input, out is out, look at them separatedly input RCA gnd for input signal... output is with power supply secondary gnd |
#27 |
Ok, so which fets do i need to put my probe onto? The set of 8? (output fets) or the set of 20 (supply fets?).
Or do i not need to check fets, does the signal go into toriods? |
#28 |
output, since you already know supply is working, right?
#29 |
Ok, from the output side i'm getting very little ac voltage ~0.2v ish.
However on 5 of the 10 (not 8 sorry) fets i get ~110 v in the middle pin DC. On the other 5 fets i get 0v DC on the centre pin but on all the right legs i get the same voltage (~110v). When i test the left pins the amplifier goes into protect. No matter where i put the gnd probe, even if its on another left leg. When the amplifier goes into protect the fan continues to run and i still get voltage on my supply side. However the buzzing noise stops coming from the caps (as the relay clicks out) Too i have noticed that across those 4 random fets (DP3/4S) in the middle of the board, i get 2 of them with ~230v AC. Wherea the other 2 i only see about 7v DC(DP1/2R)! Why is that??? Also when i test for voltage across any of these fets the buzzing from the capacitors gets much quieter. These are the 4 fet's i'm on about.
#30 | ||||||||
