UM10155 from NXP
UM10155 from NXP
Old 3rd November 2009, 02:36 AM   #11
HarryDymond is offline HarryDymond  United Kingdom
Hi monaural, thanks for the reply.
Originally Posted by monaural View Post
Third: I couldn't get any analytical solution to express oscillation frequency in terms of the input signal
(it's trivial to derive a numerical solution to the problem, but its also useless, at least for me)
Could you explain? Like I said, I don't get it; why does the oscillation frequency vary with output amplitude? Qualitatively, what's causing the switching frequency to change? Is it because the effective gain of the modulator varies with output signal amplitude?
Old 3rd November 2009, 03:14 AM   #12
monaural is offline monaural  Portugal
Since this is a non-linear system, you should not see the circuit as a static model. It's behaviour highly depends on the signal applied to it.
For example, in the extreme, try to add a carrier to the signal, at, say, 1Mhz
the ucd will actually oscillate at that fixed frequency, just like a regular class D!
well, the numerical solution is obtained, deriving the frequency response of the system (arround the comparator), applying a variable-duty-cycle squarewave to the system, and checking for Vo == Vin in the time domain.
If you know how to handle laplace transfer functions, you will get to the expression:
square_wave(t) = sum(n, from -oo to +oo, skipping n=0) sen(pi*n*D)/(n*pi)*exp(-j*D*n*pi)*exp(+j*2*pi*n/T*t)
where D is duty cycle (from 0 to 1) T is the square wave period (what we want to know)
from here, you multiply the frequency contents of the wave, with the corresponding frequency response of the branch, say G(s), so the inverting input of the comparator would be
Vi-(t) = sum(n, from -oo to +oo, skipping n=0) sen(pi*n*D)/(n*pi)*exp(-j*D*n*pi)*G(j*2*pi*n/T)*exp(+j*2*pi*n/T*t)
Assuming
Vi-(0) - Vi+ = 0, since the step occurs at t=0 (assuption I took when calculating the square wave freq. content)
then, the next commutation, at t=DT, the condition should also be truth:
Vi-(DT) - Vi+ = 0
so Vi-(0) = Vi-(DT)
Btw, do not think that Vi+ is proportional to D. It's not.
calculating it on matlab would give the answer.
I have some matlab code:
sorry about those portuguese comments, but i believe you will understand the code
anyway, you always have google translator
Code:
%cálculo da frequência de oscilação, recorrendo ao método numérico
%% primeiro que tudo, calcula a resposta em frequência da malha
clear all;
close all;
syms s;
%Atraso da malha
tau=300e-9;
L=28e-6;
C=680e-9;
Rl=8;
Rg=1000;
Ra=22e3;
Rb=2.2e3;
Cb=220e-12;
%descrição dos sistemas
%filtro passa baixo
Lpf=1/(L*C)*1/(s^2+s/(Rl*C)+1/(L*C));
%phase-lead network
A=Rg/(Ra+Rg);
tz=Cb*(Ra+Rb);
tp=Cb*(Rb+Ra*Rg/(Ra+Rg));
Pln=A*(tz*s+1)/(tp*s+1);
Cmp=exp(-s*tau);
M=Lpf*Pln*Cmp;
%% Agora que já calculou a resposta da malha(M), vai obter a frequência de
%% oscilação, em funcao do duty cycle
close all;
D=0.1; %duty cycle
T=linspace(1e-6,10e-6, 1000);
tempo=linspace(0, 20e-6, 10000);
periodo=1/3.17e5;
sinal=zeros(1, 1000);
sinalp=zeros(1, 1000);
sinal_tempo = zeros(1, 10000);
for n=-50:50;
    if(n ~= 0)
        sinal = sinal + i*(1-cos(2*pi*n*D))./(n*pi).*subs(M, s, i*2*pi*n./T);
        if(n>0)
            sinalp = sinalp + (1-exp(-2*j*pi*n*D))*(1-exp(2*j*pi*n*D))/(2*j*n).*subs(M, s, 2*j*pi*n./T);
        end
        sinal_tempo = sinal_tempo + sin(pi*n*D)./(n*pi).*exp(-j*pi*n*D)*exp(j*n/periodo*tempo*2*pi).*subs(M, s, i*2*pi*n./periodo);;
    end
end
figure(1)
subplot(2,1,1)
plot(1./T, real(sinal))
hold on
plot([1/1e-6, 1/10e-6], [0 0], 'r')
subplot(2,1,2)
plot(1./T, angle(sinal))
figure (2)
plot(tempo, real(sinal_tempo));
%% Agora que já consegui calcular o sinal à saída,vou resolver em ordem a T
close all;
dt=100e-9;
T=1/130e3;
sinal=0;
frequencias=zeros(1,10);
indice=1;
duties=linspace(0.1,0.9,1000);
for D=duties;
    frequencias(indice) = fzero(@(f) Vcomp(f, D, 100), [50e3, 1e6]);
    indice = indice + 1;
end
plot(duties, frequencias)
% figure(1)
% subplot(2,1,1)
% plot(1./T, real(sinal))
% hold on
% plot([1/1e-6, 1/10e-6], [0 0], 'r')
% subplot(2,1,2)
% plot(1./T, angle(sinal))
% figure (2)
% plot(tempo, real(sinal_tempo));
You will need this function:
Code:
function y = Vcomp(f, D, ordem)
if ordem <1
    error('Ordem tem que ser pelo menos um!')
end
sinal=0;
for n=-ordem:ordem;
    if(n ~= 0)
        s=i*2*pi*n.*f;
        resposta_filtro=3442016806722689./65536.*exp(-2833419889721787./9444732965739290427392.*s).*(6285469788699497./27153607276500459978752.*s + 1./23)./(3279375541930173./4722366482869645213696.*s + 1)./(s.^2 + 1180591620717411303424./6422418416702717.*s + 3442016806722689./65536);
        sinal = sinal + i*(1-cos(2*pi*n*D))./(n*pi).*resposta_filtro;
    end
end
y = real(sinal);
end
Old 3rd November 2009, 03:17 AM   #13
That huge line inside the function is just the frequency response function expanded, because this way matlab works faster.
Those component values are retrieved from Um10155.
Old 3rd November 2009, 03:28 AM   #14
Sorry, I haven't read this
Well, imagine a simpler system:
a comparator with delay connected to a first order low-pass filter (e.g. a resistor and a capacitor), and the output voltage directly fed-back to the comparator
Since Vcapacitor (capacitor voltage, which is also output voltage of the system) is the result of the current integral, and the current is (Vcomparator_out - Vcapacitor)/R , when mean Vcapacitor is low (, say, -0.5) when the Vcomparator = 1, the capacitor is integrating 1.5/R
When the mean Vcapacitor is higher (say, 0.5) the capacitor just integrates 0.5/R, so, charges slower
it means that higher the output voltage, slower is the charging, so, when the output voltage is higher, the capacitor takes longer to charge, and is faster to discharge, and vice versa.
as a consequence, you can see that when Vi is away from 0V, the output is something like a sawtooth.
With a simple first order system, its trivial to get a analytical solution, because the working variable (Vout) is proportional to the state variable (in this case, the charge stored in the capacitor), but for a 2nd order system, or the even more complex feedback network of ucd, it can't be done this way. However, the principle is the very same. Basically, the system reponds differently, as a function of stored energy.
UM10155 from NXPHide this!Advertise here!
What's different UCD180 and UM10155 xxxxxxx Class D 6 26th July 2008 07:19 AM
