Red Rocks in Spain has a class D amp with 200W in 8 ohm
http://www.redrocksaudio.es/e_main.html
I have just recived the price for 2 D200 amps incl. shipping (airmail) to Denmark. 130 eur.
Joined 2003
båndsei said:I have not tried their amps,but the SMPS is working fine.Silent and cold .There is a fan incl. but it is not needed for normal use.Price 239 eur incl. delivery to DK.
Ouch ... for that you could have gotten 3 amp7 kits.
D200 listening experience
I own four of the D200 modules plus two SMPS. The quality of the built is outstanding with most of the capacitors rated at 105°C and extensive use of SMD high quality parts.
The amps are dead silent with speakers rated 90-91db/watt. I added a capacitor reservoir of about 20mF/rail between the amps and the SMPS and it is really worth the investment: the soundstage opens considerably and the low frequency range tightens.
In general, dynamics is the strongest point of this amp with explosive bass, when needed. The treble is very detailed but with no harsh although not as liquid as a vacuum tube (SE class A+) amp: definitely, the D200 has some solid state timbre but, I would say, with "rounded edges".
In sum, I like this amp very very much... definitely worth the money!
- Class D
- imPULSE D200 class D amp.
