| Class D Switching Power Amplifiers and Power D/A conversion |
#2 |
Class D on breadboard ?
SivanandBalan |
#3 |
Whatz the problem ? every thing is clear from the pic itself !!!
SivanandBalan |
#4 |
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#5 |
Thank You for your response
I couldn't check the link again as I wasn't sure that it could be helpful. Immediately after submitting the message I wasn't able to edit the post for more details. I made this amplifier from off the shelf parts. I didn't have inductors. I tried without them. Thought that the inductors are probably to filter out higher frequencies. However the amplifier did nothing except very periodic ticks and that too at very low volume. Changed the gain selection pins but had no effect. Are the inductors necessary for the operation or these are just to improve the voice quality? How could I wound these inductors at home (22 and 33 mH)? I do have feright rods. |
#6 |
yes, unfortunately they are required. I tried to do without them myself but had the same problem.
#7 |
Thank you for your reply, audiomodder.
Still I have not figured out how to wind these inductors myself. |
#8 |
What kind of ferrite rods u have ? ...even a drum inductor will suffice..get urself an LCR meter or borrow one...wind few turns and measure...its easy since the inductance required is only 22 micro henry..and the values r not super critical...first decide the loud speaker impedance..and topology single or bridge
SivanandBalan |
#9 |
no problem
![]() yeah, values are def not too critical...and i found if you get the wrong value by a large margin all you get is a lower output, but it will still function. be careful to make sure the inductors can handle the output capacity too, im using something like 1A or 2A capacity and they get kinda warm when playing music. |
#10 |
Thankyou Sivan and AM,
I baught 22uH inductors. These look just like resistors (Red Red Black strips). But I have not tested yet. Size is a little larger than quarter watt resistors. Hope to test the circuit today. I don't have inductance meter. For ferrite rods I have old TV flyback transformer's core. Wouldn't it do? |
| TPA3122D2 based amp just clicking and hissing along | cynric | Class D | 6 | 11th July 2009 01:22 PM |
| Tpa3122d2 Class D Audio Power | aris69 | Class D | 0 | 24th June 2009 10:50 PM |
| problem with my amplifier | marcojhp | Solid State | 3 | 24th January 2007 08:34 PM |
| sub amplifier problem | testarossa2k | Subwoofers | 4 | 25th August 2006 06:36 PM |
| RF Amplifier Problem | xitronics | Solid State | 9 | 15th April 2006 05:48 PM |
| Page generated in 0.10710 seconds (77.56% PHP - 22.44% MySQL) with 11 queries |
