Hypex UcD AS2.100 - Page 39 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th July 2012, 08:12 AM   #381
i guess the TV-code are RC5 protocol?
wich is used on most DIY pre-amps/cd-players.
Old 17th July 2012, 08:14 PM   #382
aryysy is offline aryysy  Finland
Originally Posted by Matthijs_Hypex View Post
Yes cutting off the sensor would do the trick but is a permanent solution. I can tell you we're working on a update where you can also select 2 types of IR commands. The first is the current one (TV-codes) and the second one is the one that matches our new "Hypx-remote" and will not responde on other remotes. I hope to release the new version soon but I can't give you a hard date for this.
Gr8 news, Thank! Ill keep tuned and be waiting for update!
Please take in to consideration to add tick box to hypex control panel to "disable volume controls and save current volume settings"
BR
Antti
Old 11th August 2012, 11:33 AM   #383
burnett is offline burnett  Germany
Beforehand I would like to say the as2.100 is a really great piece of electronics.
I just came around a really annoying problem. My old trusty laptop just died and my new laptop with Win7 64bit won't recognize the as2.100. What can I do?
Jochen
Old 11th August 2012, 10:23 PM   #384
Hello,
I am planning on building a set of Proac Studio 100 clones. I cannot decide between using the Hypex Plate amplifiers or using the Hypex Modules. Which will be the better sound? The plate amps will offer many more options with the active crossover and will save much time in constructing two monoblocks. If the sound result will be equal or better with the plate amps will the AS2.100 do the trick or will I benefit from the higher powered PSC2.400?
Thanks!
Old 13th August 2012, 06:51 AM   #385
Jochen
Hi Jochen,
This is a know issue and fixed in the latest version, firmware V2.7. But to update the firmware you obviously need a USB connection. I'd like to send you instructions for a workaround through email, could you contact me (or anyone else with this problem) at matthijs at hypex dot nl.
Old 16th August 2012, 06:33 PM   #386
Hi Matthijs,
I did the update to firmware V2.7 and now everything is fine and feels even more stable than before.
Jochen
P.S. It would be great if you could download the memory of the AS2.100 back to the filter designer.
Old 20th August 2012, 06:36 AM   #387
Hi Matthijs,
Jochen
Good to hear you can notice the improvements.
It's hard to load the filtersettings back from the modules because of some technical issues but to have it kind of fixed we made the file-name function.
First the user must create a file before it can load the filter settings. And together with the filter settings the file-name is on the AS2 or PSC2. You can readback the filename under "about". By this you can see what filtersettings are loaded.
Old 11th September 2012, 04:50 PM   #388
pos is offline pos  Europe
pos's Avatar
Hello Matthijs,
I am using a pair of AS2-100d to power two-ways speakers with a compression driver for the high. The high sensitivity of the compression driver makes the residual noise of the DSP/amp combo quite noticeable.
So far I am using Lpads to reduce the level after the amp (in fact I am using an autoformer, which is better, but still not ideal). I would like to know if the gain can be reduced between the DSP and the amp?
I see that the last revision of the DSP2W module (as used in the PSC400) has jumpers to reduce the output gain by 10dB. Is this also possible with the low profile version used in the AS2-100?
Dank u
Thomas
Old 12th September 2012, 07:06 AM   #389
Unfortunately there is no possebility to lower the gain on the AS2.100 because it is not supported on the hardware.
Old 13th September 2012, 08:52 PM   #390
pos's Avatar
Thank you for your anwser.
So nothing can be done, even by removing or changing some smd resistors?
I guess I am stuck with the autoformer (and condenser, until I am fully confident the dsp will never "loose" its parameters and send 20Hz signal to my compression driver ). That is not that bad: the USD180 should have a very low distortion on a 64 ohms load (-18dB setting).
Also, would it be possible in a future firmware update to prevent the "clic" that the unit does when acquiring spdif sync?
I usually set the volume on the speakers at 0dB and control the volume on my source (PC or TV), so the click are quite loud. Is it the same on the PSC400?
thanks
FS : Hypex ST PSU korben69 Swap Meet 1 2nd July 2010 11:46 AM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 400. ian walker Swap Meet 3 14th January 2008 03:32 PM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Copyright 1999-2017 diyAudio
