| Class D Switching Power Amplifiers and Power D/A conversion |
#351 | |
A SMPS will be a bit of overkill because there is already a power supply section on the board. The extra 10VAC could be made with manual windings or indeed with a second transformer. |
#352 | |
#353 |
Sure that would be nice, but form a budget point of view, probably double or triple the price for the same amount of channels?
#354 |
Correct... However we do not recommend modifying one of the plate amps to increase output power. Not to forget you will lose your warranty.
#355 |
So that would lease my other option for the PSC:
Use a digital volume control via one of the ASRC chips available (most of them have some kind of attenuation register that is usable for this). This would also mean adding an extra ADC for analog. Al of this will also cost money and needs to be designed and tested.. So the last one would be using the USB protocol to do this. I guess Hypex won't reveal the volume part of the protocol? |
#356 |
Dear friends,
I am about to order 2 AS2.100 for my speakers. Each will power two SB Acoustics SB17NRXC35-8 in parallel for the low-mid freqs and 1 ESS Great Heil in a bipole/dipole. The xover would be around 1600-2000hz. The whole thing should be quite efficient at 92db. I am wondering if the AS2.100 would provide enough power to drive them loud without distortion. I wasn't able to find any data about THD/THD+N at full power and (for another project) the power output under 8 Ohm load for the AS2.100. Thank you in advance for any help. Oreste |
#357 | |
The AS2.100 uses two UcD180LP modules, you can find more information about the THD and power in the datasheet. Do note that in the AS2 the power is limited by the transformer and therfore max 90 to 100Watts in total. At 8Ohms the UcD180LP could deliver up to 120Watts on a more powerfull supply. |
#358 |
Thanks,
as I see it, because of the limited supply of power, the as2.100 should not be able to reach power levels where thd could become a problem. I'm still wondering if the watt output would be sufficient to drive my 4 ohm 92db speakers in a 25 square meter room. Sorry for that, but, as you probably noticed, I'm still a novice at DIY |
#359 |
Since the speakers that the as2.100s will power are going to be a sealed design, I was wondering if the as2.100 is airtight and if it is going to have cooling problems in a sealed design.
Thanks Oreste |
#360 | |
Gerhard |
| FS : Hypex ST PSU | korben69 | Swap Meet | 1 | 2nd July 2010 11:46 AM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 400. | ian walker | Swap Meet | 3 | 14th January 2008 03:32 PM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
| Page generated in 0.13640 seconds (78.94% PHP - 21.06% MySQL) with 11 queries |
