Hypex UcD AS2.100
Hypex UcD AS2.100
Old 10th December 2009, 02:06 PM   #111
doug20 is offline doug20  United States
Originally Posted by Matthijs_Hypex View Post
It will be made! I will be a very good product for Hypex, and also to show what we can do with dsp.
I hope to get the module working in the first quarter next year, and if we manage to do so it will take an other 10 weeks to get the first boards on the market.
However it can be delayed when some projects for other companies must be finished in the same period. We are working on such projects but we are not sure if we can do these projects.
Will it have unbalanced (RCA) input/outputs?
Old 10th December 2009, 02:14 PM   #112
Jan-Peter is offline Jan-Peter  Netherlands
Is this important?
To come back to your question, no.... It's rather easy to change a symmetrical input to asymmetrical, the other way around is more difficult....
Jan-Peter
Old 10th December 2009, 03:37 PM   #113
Originally Posted by Jan-Peter View Post
Is this important?
Jan-Peter
Yes, that is important to me.
Old 11th December 2009, 06:27 AM   #114
Matthijs_Hypex is offline Matthijs_Hypex  Netherlands
http://www.hypex.nl/docs/wiring.pdf
You can connect unbalanced sources to a balanced inputs by connecting the - to source ground, see picture in the document.
Old 11th December 2009, 01:04 PM   #115
Yes, Im well aware of XLR to RCA stuff. I have 3 DCXs and 2 of them connect to unbalanced AVRs, I even have cust XLR to RCA cables with a ground Wire out the RCA end for grounding to try and eliminate the hum.
I have an application that I want strict RCA to RCA.
Old 11th December 2009, 09:25 PM   #116
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hypex UcD AS2.100
I see only RCA on plateamp
Are you saying that its easily converted to balanced, by "diy mounting" XLR, and rearrange connection inside plateamp?
Thats how I understand you
I may want to use it in a PRO design (diy fore my own use)
Old 14th December 2009, 06:56 AM   #117
The AS2.100 has only a RCA input.
The cables I mentioned earlier are for conversion in a excising setup, where you got a Balanced signal to unbalanced and vice versa. It will not work when you want to "make" a unbalanced input balanced. This is only a solution for connecting the two sources. Do you understand what I'm trying to say?
The PSC2.400 is provided with balanced input.
Old 14th December 2009, 12:52 PM   #118
Hypex UcD AS2.100
Yes, I understand so far that the balanced conversion cable is suggested in diy Hypex modules manual
PSC2.400
Balanced input ? I take it its a bigger version of this plateamp with dsp ?
When will it be on your web site ?
Old 14th December 2009, 06:22 PM   #119
Hypex UcD AS2.100
Ah, ok
Hypex UcD AS2.100
http://www.hypex.nl/docs/PSC2.400.pdf
But dsp sub out seem gone now
I actually liked that option
I supposed it could make a nice 3way with a simple slave amp
But added preset options could become handy
Old 15th December 2009, 07:35 AM   #120
Ah, ok
Hypex UcD AS2.100
Yes we used the suboutput for better SNR of the woofer output.
But for a powerfull 3-way system you could use a second PSC2.400 in bridge. this one could filter and power the subwoofer. The signal will be looped through to the top for mid and high channel.
This will give you a lot of power and a lot of design freedom.
Hypex UcD AS2.100Hide this!Advertise here!
FS : Hypex ST PSU korben69 Swap Meet 1 2nd July 2010 11:46 AM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 400. ian walker Swap Meet 3 14th January 2008 03:32 PM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
