| Class D Switching Power Amplifiers and Power D/A conversion |
#91 |
Jan-Peter,
Is a digital input only version (of standalone board) possible? I already have no shortage of good A/D, it would be great if I could reduce the cost of the DSP board.
#92 | |
Jan-Peter |
#93 | |
Do you have some informations about availability and price for those PCB ? |
#94 | |
Does that mean 1 or 2 stereo source ? "Symmetrical inputs" I sure dont hope this means balanced input/output only ? Last edited by tinitus; 19th September 2009 at 10:33 PM. |
#95 | |
2 channels/signals. So that will be only stereo. Besides the analogue input there is also a AES/EBU input and a USB audio input.
For more audio inputs (both analogue and digital) we are planning to make an input selection boards with all the connectors. The High end label is given because we do everything to make this product the best audio+dsp solution. So we've chosen verry good converters, very high end supply solutions for all of the audio components, a higher sampling rate (96kHz processing and up to 192kHz input) and more processing power. With all this we can realy cal it high end. But because of the complexity and that the module can be used in lots of solutions we are still working on it and will only release it when we trust it. |
#96 |
#97 | |
Regarding Processing power... It would be very good to know for exaple, how many taps could be used allatogether for FIR at 96kHz? it woud allow me an insight regarding power... Thanks, Tamas |
#98 | |
Is this means that when I play HD/HRx audio file with 24/192kHz, 176.4 kHz resolution audio through AES/EBU signal will be down sampled to be processed at 96 kHz? |
#99 | |
Yes, all of the signals will be converted to 96kHz/24bit. Because we think this is the best sampling rate, going up to 192kHz will not make a big difference we believe. Also considering the loss of processing power when we go up to 192kHz. The total processing power is not jet know because we've not jet started with this. And it will depend on all the other functions in the dsp, like filters delay and limiters etc. |
#100 |
Anything new on this, estimated release date?
I am an OEM who is very interested. |
| FS : Hypex ST PSU | korben69 | Swap Meet | 1 | 2nd July 2010 11:46 AM |
| Question for those who have tried hypex smps with hypex modules | avian | Class D | 12 | 3rd March 2009 09:30 AM |
| Hypex UcD 400. | ian walker | Swap Meet | 3 | 14th January 2008 03:32 PM |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| FS: Hypex UcD 400/180AD, hypex toroid | Archmage | Swap Meet | 4 | 14th November 2006 04:23 AM |
