Go Back   Home > Forums > Amplifiers > Class D
Old 14th May 2009, 10:34 AM   #1
oon_the_kid's Avatar
Default Tripath chips shootout
I've been thinking about building another tripath amplifier. I've built one based on the TA2022.
I was wondering if there is somebody out there who have heard a whole bunch of Tripath Chips, TA2020, TA2022, TA2024, TK 2050 etc and have some comments on the sound coming from them.
Which sounds bests....?
I don't need a lot of juice, I reckon 20W should be enough for me...
Oon
Old 14th May 2009, 07:29 PM   #2
joemana is offline joemana  United States
I'll recommend TA3020 especially the design by 41Hz Truepath. It sounds way better than TA2022. If you'll check the 41Hz forum, you will find out the favorable comments on TA3020 compare to almost any Tripath model.
Joe
Old 15th May 2009, 01:20 PM   #3
Thanks Joes,
But i was thinking of something a bit lower powered. I find most amps (maybe not tripath) tend to sound a bit lethargic unless it is driven into their sweet spot. At 300W, I doubt I will even hit the 5% point...
Oon
Old 15th May 2009, 01:26 PM   #4
Pano is offline Pano  United States
Pano's Avatar
TA2020 was always my favorite, if you can live with the low power.
Take the Speaker Voltage Test!
Old 23rd May 2009, 03:05 PM   #5
Originally posted by oon_the_kid
Thanks Joes,
Oon
You can make the big-iron Tripaths behave more like the smaller ones:
- They can operate on a much lower voltage than the default (at least down to 18V).
- You can also lower the gain, gearing the noise floor away from reproduction at 300W and towards 20W operation
The reason why you'd want to do something like this is that the bigger, more complex chipsets do sound better, irrespective of power. The datasheets show this: There's simply less distortion. Subjectively, terms like "blackness", "microdynamics" and "soundstage" have been used.
Of the 41Hz line, pick one of these, starting with the best sounding:
- Truepath - TA3020
- Amp15 - TA3020
- Amp4 (maybe Amp11) - TC2001 + TP2050
- Amp6 - TA2020
AFAIK this that is the descending order of build difficulty, and also the descending order of sound quality. Take a close look at the Amp4!
Old 26th May 2009, 01:24 AM   #6
Thanks for the reply.
Found a thread that seems to address some of my questions.
Which Tri Path Amp
Thanks for the info on the truepath. I bought the Amp6 and quite happy with it.
I think the Truepath specified voltage is +-35, so it will still be quite a powerful amplifier. I am still a bit worried about underdriving it.
But the TK2050, Amp 4 sounds interesting. Had very good reviews from Winsome mouse and Virtue one.
Many thanks.
Oon
Old 26th May 2009, 12:03 PM   #7
I had the same thoughts a few months ago, I got it confirmed that the Truepath (and any other TA3020 design) can be taken down to +/- 18V, at least. All it takes is a few different resistors to change gain and voltage sensing, a very simple calculation. (Also, I must state that underdriving these amps isn't as bad as it might seem, if they're properly built w.r.t. noise and appropriate gain.)
Old 27th May 2009, 07:20 PM   #8
cbriere is offline cbriere  Canada
cannot access web site:
http://www.tripath.com/
is the company closed?
Old 27th May 2009, 07:48 PM   #9
theAnonymous1's Avatar
The End For Tripath??? Say It Ain't So!
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 31st May 2009, 01:41 AM   #10
Try it again. 41Hz upgraded their site maybe, that is why you can't login.
http://www.41hz.com/
Joe
Where do I get Tripath Chips??? Rod_T Class D 8 28th October 2007 01:35 AM
Where to buy tripath chips? bigmike216 Class D 1 27th August 2005 06:31 PM
Purchase of Tripath chips/group buy? protos Class D 3 9th August 2005 09:15 AM
tripath chips supplier CRFX Parts 2 21st November 2004 07:59 PM
Where to buy Tripath chips in US? owel Chip Amps 15 20th May 2004 07:49 AM
Page generated in 0.09288 seconds (87.25% PHP - 12.75% MySQL) with 10 queries
