Go Back   Home > Forums > Amplifiers > Class D
Old 14th May 2009, 01:47 AM   #1
Default Reverse polarity protection, better way without diode.
It's not very safe to run equipment without this protection. I've burned a few things up plugging them in the wrong way. Needs only a P channel power MOSFET and one resistor.
I've tested on TA2024 board, replacing on board diode. Voltage drop measured as .02v at idle with the mosfet I used, an SFP9644 salvaged from a broken monitor. I haven't had a chance to listen yet.
A link to the original article:
MOSFET reverse polarity protection
I think this should be fine with just about any gear, as long as you choose a suitable mosfet? And double check the GDS pinouts!
Old 14th May 2009, 06:25 AM   #2
wwenze is offline wwenze  Singapore
This is almost like a simple series voltage regulator, without the zener diode. BTW all our gear should have a voltage regulator, right?
Old 14th May 2009, 07:19 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
You run current backwards through the mosfet and since you have signal on the gate you won't get a diode voltage drop. You'll get only Rdson * I.
/Per-Anders (my first name) or P-A as my friends call me
Old 14th May 2009, 02:57 PM   #4
It doesn't mention it on the link I gave, but the 1M ohm resistor, I believe, produces a soft start delay of about 100ms. Probably not that important, but could be useful if it can be tweaked further.
It seems to do the job well enough.
Old 16th May 2009, 09:01 PM   #5
MikeHunt79's Avatar
What are the reasons to avoid using a diode apart from the voltage drop?
Old 19th May 2009, 08:44 AM   #6
Pafi is offline Pafi  Hungary
The unability to sinking current. (in case of supply pumping)
I prefer nMOS on the negative.
Extremely smart reverse polarity protection peranders Parts 5 15th January 2011 11:48 AM
Anti-reverse-bias protection diode vs. performance hollowman Power Supplies 5 29th September 2008 12:15 AM
Reverse Polarity icecoolwas Car Audio 2 28th April 2008 09:30 PM
Reverse Polarity of Mid driver (3 way) SamClassA Multi-Way 1 29th October 2006 09:27 AM
subwoofer polarity reverse kdlsrinu Subwoofers 12 22nd May 2006 09:39 AM
Page generated in 0.08814 seconds (70.57% PHP - 29.43% MySQL) with 10 queries
