Go Back   Home > Forums > Amplifiers > Class D
Old 8th December 2009, 07:02 AM   #811
Ouroboros's Avatar
For the filters and Zobels on the output stage, you're best to go to the ST Micro web site and download the data sheet for the STA505. The Tripath output chip is simply a re-branded ST505.
Old 8th December 2009, 10:31 AM   #812
Alastair E's Avatar
Originally Posted by MikeHunt79 View Post
Hi, where is that quote from? I cannot find any mention of Schottky diodes in the Tk2050 datasheet or the Sure manual... This amp does not use the TA2020 chip like the Lepai does however!
Hi Mike...
I was asking, as I know there was an issue with the 2020, and as the format is very nearly the same as to the O/P stage MOSFETS and RF Filter-stages, it could also be subseptible to the same 'mode of damage' that the 2020 suffered from when the supply was near its maximum and 'difficult' loads were driven.
--A few years ago, on the Tripath website, (Long since gone....) there was a single leaf about the overshoot protection using the diodes....
Das Beste Oder Nichts
Old 8th December 2009, 05:27 PM   #813
MikeHunt79's Avatar
Originally Posted by Alastair E View Post
Hi Mike...
I think this information about overshoot protection using the diodes is within the TA2020 datasheet, that's where I remember reading it and also seeing 8 diodes on the schematic.
I do not think this amp needs these diodes, and even if it does, you can play it safe and feed it 32v or less.
Old 8th December 2009, 06:15 PM   #814
Alastair E's Avatar
Fair enough....
They are cheap enough to play around with anyway...
Ive been looking at the 4 ch. version. Any comments on this one in particular?
Old 8th December 2009, 11:45 PM   #815
e_fortier's Avatar
Default What value for output caps and Zobel
I just bought last night a second 2 x 100W, these are pretty good.
What are you guys using for the output caps keeping in minds that I will keep the present output coils (22uH shielded type)
What I'm looking for is the value for C33, C36, C35 and also the value for the Zobel, I am aware that it is a matter of compromise but please suggest values that have given you great sounds. A while back at the beginning of this thread someone had suggest great result with 0.22uF Polyester Film cap so I already bought 20 of them, I hope I can use them
Thanks for your help.
Eric
Old 9th December 2009, 02:28 AM   #816
sendler is offline sendler  United States
Default 4X100 problems
Fair enough....
Lots of problems.
Sure Electronics New Tripath Board 4*100W class-D Amplifier Board
Scott
Old 9th December 2009, 02:58 AM   #817
Default Remove R14/34
I guess Belden is the yardstick here, and it is good that it is available both sides of the Atlantic. Am I right in assuming Belden magnet wire has red insulation?
Belden makes both types. Solder strip and high temp which must be scraped. My cheap stuff is solder strip and the Belden is high temp and has a darker red color.
I can use the internal gains of the DCX to achieve -10Db of attenuation without any problems.
Keep digital attenuation as close to zero as possible for the best resolution.
By the looks of the schematic, could a pot be used in place of R14/R34?
I haven't tried it yet because stepped attenuators can click once in a while and the TC2000 are fragile to input spikes but removing R14/34 should be a good idea if adding a volume control. The input impedance of the amp will increase from 11k to 22k and work better with the passive control. Stepped volume control is a must have in a DCX active cross setup so all of the channels can be turned up and down the same number of clicks and stay synched.
I'm using a 20k pot right now, and it works fine. I guess a 10k should be ok also.
With the volume control right on the board, minimal/none wire between it and the next active stage, you might get away with 20k. No way to tell which value might sound best but to listen. Higher values are an easier load for your source/DCX. Lower values have lower output impedances which interact with any following wire less.
Scott
Old 9th December 2009, 03:10 AM   #818
pheonix358's Avatar
Fair enough....
My first one fried, second one is fine, no problems. Sounds great right out the box. Sure are good about replacing them. They seem to fry or not. Some bugs have been fixed and the new ones seem to work.
Terry
What we don't understand is called magic.
Old 9th December 2009, 04:55 AM   #819
Hi Guys,
I'm in the process of building the output filter from the tripath data-sheet. Im not quite sure where the ground leads for the output capacitors go. Im using a separate breadboard that will be held in place by screws.
Old 9th December 2009, 07:48 AM   #820
I think i overlooked something. The 4x100W 4Ohm amp. is already bridged, so its not possible to use my 120W 8Ohm speakers at max. performance?
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright ©1999-2013 diyAudio
