Sure Electronics New Tripath Board tc2000+tp2050 - Page 51 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st September 2009, 01:23 PM   #501
swkbkk is offline swkbkk  Thailand
Sorry to hear about your misfortunes, ElFishi and SimonKit
Old 21st September 2009, 02:13 PM   #502
Thanks, I hope to learn from it. Anyway, I upgraded 2 other amps (a gainclone and the Trends Audio TA-10) this weekend with the Mcaps from Mundorf I tried on this Sure Electronics amp because I like them very much! Next time I will be more careful with the PCB.
Old 21st September 2009, 03:15 PM   #503
ElFishi is offline ElFishi  Europe
ElFishi's Avatar
thx -
Old 21st September 2009, 09:51 PM   #504
Default Is there a Sure board hierarchy of suggested mods?
I would think that replacing the input caps to something like the Dayton poly foil caps is a good start for maximum improvement in sound quality for the least amount of work/money. I've gone through all the posts and have the glazed eyes to show for it. Is there anyone out there who might be more organized or knowledegable than me (I think: "yes"), someone who's willing to make a list of what might be the best upgrades for most DIYers? I'm thinking something along the lines of:
I. Must Do's: swap out input caps, upgrade signal path resistors, etc.
II. Worth Doing for Better Sound: swap out stock inductors for toroids, etc.
III. Might Be Worth Doing: battery PS
The above list is just an example, surely someone has a better idea . . .
Thanks!
Old 21st September 2009, 09:54 PM   #505
Default Volume Control, Bypassing It
If I want to just use the Sure board as an amp, and do not want to have a volume pot connected, is there a place on the board I should short out or leave open? I'd prefer to have my preamp control the volume and to have the amp not have a pot controlling resistance on the input.
Old 22nd September 2009, 01:17 AM   #506
vaughn is offline vaughn  United States
Anybody know where the 2.5V connection is on this board? I want to try a capacitorless connection from my transformer output DAC as Panomaniac describes in the transformer coupled DAC thread.
Old 22nd September 2009, 06:09 AM   #507
No problem. I used it this way combined connected to my passive preamp from Antique Sound Lab http://www.uhfmag.com/Issue62/aslpassive.html
There is nothing you have to change on the board ... however if you have an active pre-amp I would set the gain on the board of the Sure amp to the lowest setting with the dipswitches.
Old 22nd September 2009, 06:29 AM   #508
ElFishi's Avatar
my take:
I.
- Input caps
- tank caps (and thus depending on your PSU also a soft start)
II.
- Input and feedback resistors
III.
- output filter incl. toroids
- voltage regulator
- re-route power rails on PCB and remove diodes (amp likes every bit of voltage)
IV. Might not be worth doing
- re-wiring pins 24 on both TP2050s to 21,22 (Vdd) instead of gnd
- exchange C22&27 for 470pF as per the TC2000 data sheet
Old 22nd September 2009, 06:44 AM   #509
ElFishi's Avatar
There is no 2.5V connection. It is the virtual ground of the input opamp of the TC2000 fed with 5V supply voltage. Plus there are pots (R5&R26) to fine tune the 2.5V such that there is no output offset voltage.
There are people though who run tripath based amps capless:
http://www.diyaudio.com/forums/class-d/101344-tripath-input-coupling-caps-post1201831.html
Old 22nd September 2009, 11:20 AM   #510
dr_vega is offline dr_vega  United States
Originally Posted by ElFishi View Post
my take:
I.
- Input caps
II.
III.
- voltage regulator
A very good list, ElFishi. I think I'd add the Zobel filter to group I or II, more for safety than sound quality.
-dr_vega
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright 1999-2017 diyAudio
