| Class D Switching Power Amplifiers and Power D/A conversion |
#31 |
Thanks Audio1st for your precious tweaks, I'll also remove C17 and C25. Then I'm planning to change C16 and C24 with mundorf ones (1uF I suppose)
in ordar to avoid overheating I changed the termal grease with the Zalman ZM-STG1, a great one that I recommend using even with CPUs For the inductors which gauge I have to pick? Cheers, KingBowser |
#32 |
Could not resist a change of the input caps, I just needed to see what it is capable of.
The original 1uF + 220nF must have limited the low end more than I thought it would, changed to the obligatory 2u2F and can definitely hear a difference in the low notes. Also the change seems to have opened up the sound and added even more clarity. Just used what I had handy for now (Wima). I have no inclination to change the inductors so have no suggestions in this area. |
#33 | |
On the picture I see two resistors on the input, for what are they there for? I'm still waiting for my board to come. Regards Aleš |
#34 | |
Hi, Those two resistors where in-place of R14 and R34, the way I have now connected the caps, the original smd resistors are back in use. |
#35 |
Audio1st;
I am very new to DIY and electronics so please bear with my lame questions below: 1. On the picture with the red coloured cap, am I correct in seeing that you have replaced the original C24 (220nF) with your red one (2.2uF) and killed C25 (1uF) effectively maintaining the same capacitance at 2.2uF? 2. What benefit does this mod provide? Is it kind of replacing a low quality cap with a better quality one at the same capacitance? 3. Is it also possible to replace them with a higher capacitance, say 4.7uF and if so, will providing the higher capacitance improve the sound quality? 4. And finally what kind of monsters are the white ones? Thank you so much in advance for your expertise and time! |
#36 | |
I suspect this has to do with the BBM (dead time) being too short. Pins 25 and 26 contol this, tho the datasheet does not say how. Usually both pins are pulled up to 5V. I would guess that pulling the pins low or open would change the BBM, just don't know how. Will have to do some digging to find out!
Take the Speaker Voltage Test! |
#37 |
Hi swkbkk
1 Yes, I have replaced the original 4 input caps for the two red caps. 2 Yes, the original caps, especially the two 1uF smd's are poor quality. 3 Replacing with anything larger than 2u2F will not make much difference to the sound, but may cause a thump through the speakers when you turn the amp on.. 4 The "best" cap in the signal path is what we aim for, no cap would be better but with this type of amp that is not really an option.. Regards. |
#38 |
Hi Panomaniac,
Nice to see you here. Thanks for your input, the chips get hot whether playing music or just idle, changing gain has no effect either.. I wonder if the 8 resistors between the TC2000 and the TP2050 are well matched enough, could this cause heat in the chips? The data sheet states 1% tolorence on these resistors. Maybe the twin chip model just needs a bigger heat-sink? |
#39 |
Hey A1 - I still haunt the Class-D forum, just don't post as much as I used to. (you'll see me more in the loudspeaker section).
I did find the BBM settings in another datasheet. Most designs for the TC2000 I have seen follow the datsheet and pull both BBM pins up to +5 - or "logic high." This gives a dead time of 0ns. That means low distortion, but more heat bcause of more shoot through. I might be worth experimenting with other dead time settings. Here is a list of the settings when the pins are pulled either hi or lo. BBM1 BBM0 Delay 0____0____120 ns 0____1____80 ns 1____0____40 ns 1____1____0 ns A setting of 40nS ought to reduce heat without raising distortion too much.
#40 |
Thank you, audio1st, for your answers.
When I get my board, which has only one TP2050 chip, I will observe if it suffers from the heat problem too to help determine if the heat problem in the twin chip version is due to the inadequate heat sink. |
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 11:41 AM |
| Page generated in 0.11065 seconds (66.40% PHP - 33.60% MySQL) with 11 queries |
